LSDs on Integras Pros/Cons
Old Feb 15, 2007 | 08:45 PM
El Lento DB8's Avatar
Default LSDs on Integras Pros/Cons
I was just wondering what are the advantages of installing an LSD on an Integra or getting a JDM Type R tranny w/LSD? I am asking this because a friend of mine said that it will be a waste of money since it will cut my top end power.
Old Feb 15, 2007 | 08:47 PM
youdontknowmeeither's Avatar
Default Re: LSDs on Integras Pros/Cons (El Lento DB8)
it'll cut your top end speed, not power.
Old Feb 15, 2007 | 08:48 PM
Default Re: LSDs on Integras Pros/Cons (zachlange)
Is there any way to prevent this from happening?
Old Feb 15, 2007 | 09:55 PM
b16er's Avatar
Dont install the LSD....?
Old Feb 15, 2007 | 09:58 PM
numbnuts22715's Avatar
the pros definitely outweigh the cons.
by the time it cuts out, you'd benefit more by shifting anyway.
Old Feb 16, 2007 | 12:07 AM
ImportMotorSpec's Avatar
Default Re: (numbnuts22715)
The pros are way better than the cons.
It isn't going to cut your top end speed by enough to worry about. Woo hoo 4 mph. If you want that extra mph, add some power.
Any driving condition it is ogin to benefit. Snow, rain, etc. You will have better traction.
Old Feb 16, 2007 | 12:27 AM
Haleiwa-Brando's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Lento DB8 &raquo;</TD></TR><TR><TD CLASS="quote">I was just wondering what are the advantages of installing an LSD on an Integra or getting a JDM Type R tranny w/LSD? I am asking this because a friend of mine said that it will be a waste of money since it will cut my top end power.</TD></TR></TABLE>
No more listening to this friend of yours . In regards to the JDM tranny, this debate in the ITR section has been milled over time and time again. I don't know what Integra you plan on putting this in so I couldn't go over the gear ratios. I do know that when comparing the final drive of the JDM R tranny to the USDM R tranny, the differences are still minimal.
Acceleration will be very slightly better through the first few gears, but your top end will also drop off slightly. In the Best Motoring video, as an example, they tested two R's with both final drives in a head to head battle. Totally predictable. The R with the 4.75 accelated slightly faster than the other, but near the end the R with the 4.40 caught up and the both netted the same exact 1/4 mile times.
As an example, driving in fifth gear...at freeway speeds the difference would be a few hundred RPM higher over the USDM R tranny.
You also can't go wrong with an LSD. Promise.
Old Feb 16, 2007 | 02:46 AM
martyball619's Avatar
Default Re: LSDs on Integras Pros/Cons (Haleiwa-Brando)
i have the JDM R 4.7 FD tranny. makes city street cruising very enjoyable. i love it. i rip thru VTEC real fast. you'll definitely feel that "umph" when you're stepping on the gas. the only downfall is that if you like to drag, after 3rd gear, itll be a drop off into 4th as the gear ratio turns into the GSR's. as for the LSD, it gets better for corners and taking off. so yeah the JDM R tranny is a good investment if u want the quicker acceleration in the street. the top end speed will max out faster.. but hey.. would u rather get to 120 mph in 5 second or get to 140 mph in 20 seconds? besides.. who cruises in the 140 mph zone ne ways
Old Feb 19, 2007 | 08:23 AM
b20acura's Avatar
Default Re: LSDs on Integras Pros/Cons (DC2SiR)
LSD FTW
Old Feb 19, 2007 | 08:42 AM
IntegrasAreBest's Avatar
lsd is awesome! you will not regret it!
spurge
11
Aug 9, 2007 06:20 PM
Hwy100IVTEC
Nov 30, 2006 06:30 AM
4drGpGSR
Jun 12, 2005 04:19 AM
turbotime
10
Jan 1, 2005 04:20 PM
mr devious illusions
Mar 16, 2004 11:27 AM
