LSD install problems...
Old Mar 2, 2004 | 05:38 PM
mingbling's Avatar
Default LSD install problems...
on this website..
http://tech.hybridgarage.com/tech/lsd/
it says that the shims go on the bottom half of the transmission casing, but the honda parts guy showed me a diagram showing that the seal actually goes on the top half of the transmissin case?
Does it matter which one its on? thanks
Old Mar 2, 2004 | 06:09 PM
Dan GSR's Avatar
Default Re: LSD install problems... (mingbling)
you want the shim that goes from
41441-PL3-B00
41442-PL3-B00
41457-PL30-B00
depending on the spacing, and what shim you need
Old Mar 2, 2004 | 06:12 PM
Dan GSR's Avatar
Default Re: LSD install problems... (Dan GSR)
the shim should go on the gear side of the case
not the clutch side of the case
Old Mar 2, 2004 | 06:22 PM
mingbling's Avatar
yes. and according to that article i showed you guys... it assumes that there is no shim in the bottom half of the transmission housing (the clutch side), but according to this diagram on acura, there is a thrust shim that needs to be installed.
So.. do I need this shim (part # 9 on diagram)?? and last question, my feeler gauges are in inches, does autozone sell feeler gauges in mm?? thanks
Old Mar 2, 2004 | 06:32 PM
Dan GSR's Avatar
that diagram is a generic diagram
what year is your trans case?
are you using the roller bearing type or the sealed bearing type for your diff?
#9 is only used in conjunction the older style differential bearings
Old Mar 2, 2004 | 06:38 PM
IN VTEC's Avatar
In the picture, that's not the bottom of the bellhousing. It's actually the cover.
Edit: Dammit...that's what I get for watching the Real World.
Old Mar 2, 2004 | 07:04 PM
Dan GSR's Avatar
Default Re: LSD install problems... (IN VTEC)
early bird gets the worm
Old Mar 3, 2004 | 03:29 PM
mingbling's Avatar
i just popped my differential out of the gsr tranny case. on the transmission housing, after i popped the shims meant for the preload for the original bearing, there seems like there is a c-clip shim, but when i tried to remove it, i realize it is something that is part of the transmission housing. Is that correct? I shouldt try to remove it right?
I kinda knicked it while trying to remove it. Do you think that might cause any trouble in the future? It seems as though the bearing sits on it, but doest spin on it, so i'm thinking its still okae. Thanks
Old Mar 3, 2004 | 04:45 PM
Dan GSR's Avatar
thats just a retaining clip , that holds the counter shaft in place
the.hamburglar
Sep 14, 2005 03:17 PM
tekstyle
Oct 13, 2003 01:49 PM
Andrew 825SM
Sep 17, 2003 05:59 PM
Preludster
Oct 10, 2002 09:12 PM
