lsd
Old Aug 21, 2003 | 11:06 PM
deeweezy's Avatar
Default lsd
if i get a lsd would the grinding in my transmission stop
Old Aug 21, 2003 | 11:14 PM
Slain's Avatar
If there is grinding in your tranny. No a lsd will not stop it, but while you are tearing apart the tranny to put a lsd in you can purchase new synchros if indeed the synchros are the case. A search on here shows that alot of people have been using the GM synchromesh tranny fluid with alot of luck, but it only cures slight grinds and scratches dont expect it to do miracles. Good luck
Old Aug 22, 2003 | 03:40 AM
EVLTEK's Avatar
Griding will be a bearing. Commonly the thrust bearing or possibly release bearing.
Unless you have currently have a LSD about to break in which case it also makes a grinding noise (experience).
revikan
Transmission & Drivetrain
Mar 12, 2018 05:19 PM
PrecisionH23a
Apr 29, 2006 09:29 AM
mugenracer
Jun 29, 2004 07:46 PM
DOHCRX
Mar 23, 2003 08:01 AM
wizzards581
Dec 9, 2001 08:45 PM
