LS wont start
Old Dec 5, 2013 | 10:22 AM
sleet_22's Avatar
Default LS wont start
Problem started off when taking off at a green light. The rpms dropped and the car shut down and hasn't started up since.
I've replaced the Distributor, I have spark, spark plug wires are in seated in their proper spots. I've also double check that to rotor is in the proper spot (compared to the previous distributor).
The car sounds like it's trying to turn on but just can't seem to.
Any help is appreciated!
Kevin
Old Dec 5, 2013 | 10:27 AM
B_Swapped93's Avatar
Default Re: LS wont start
check mechanical timing sounds like you may have jumped a tooth or 2, after confirm fuel then confirm spark.
Old Dec 5, 2013 | 11:51 AM
hell0curry's Avatar
^^second that, also pop ur valve cover off and check if ur timing belt is still intact.
Old Dec 5, 2013 | 12:06 PM
98integralsB18's Avatar
agreed to all the above, also there is a ground on the thermostat housing. its a 10mm bolt make sure it has good contact and tight.
Old Dec 5, 2013 | 12:21 PM
sleet_22's Avatar
The fuel pump is working and I have spark as well. I'll check the timing belt when I'm off work. Thanks again for the quick replies!
Kevin
Old Dec 6, 2013 | 06:31 PM
BlazeRex's Avatar
Don't forget fuel as well. Crank it, then pull a plug, check for fuel smell on the plug. As far as spark, make sure the firing order is proper when you put the new distributor on. Good luck with finding the issue!
Old Dec 6, 2013 | 11:34 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
You saw spark come out of the wire?
You can remove a plug and that'll give off a scent of fuel if you have fuel
I would do that to each plug to make sure each cyl has fuel
If not I'd get a noid light and check the injectors are getting power
Then make sure the injectors are working
Then I would check timing as mentioned
If all that checks out and your wire order is correct
I would run a compression test!
Good luck
Old Dec 9, 2013 | 02:09 PM
sleet_22's Avatar
Thanks again for all the help, after replacing a lot of parts and still no go we took apart the motor and found that it was toast :/ unfortunate but it'll receive a new heart soon!
hondaproof
Mar 15, 2013 01:40 PM
si_motor_spt
Sep 2, 2007 06:57 PM
tarheelsoldier
Mar 15, 2007 08:46 AM
ic89
Oct 26, 2006 12:15 PM
chirp2hrd
Jun 8, 2003 03:15 PM
