LS/Vtec Question
Old Aug 20, 2004 | 09:59 AM
GWInquisitor14's Avatar
Default LS/Vtec Question
OKay so I'm about to purchase a vtec head for my ls block. I just want to know if the PR3 intake manifold will fit on an OBD-1 car. Because isn't that OBD-0 so some vacum lines might not line up or w/e? Please reply
Old Aug 20, 2004 | 10:40 AM
3.504's Avatar
Default Re: LS/Vtec Question (GWInquisitor14)
pr3 is the cast code all the way up basically. 99-00 si might give a p30 cast code on the mani, but i doubt it. if you have an obd0 mani, then you might have to T some stuff off, but you're probably going to have to T a few off anyways.
Old Aug 20, 2004 | 01:43 PM
Default Re: LS/Vtec Question (3.504)
Alright thanx, ill ask the guy what car or year it is off of after i get back from work tonite
Old Aug 21, 2004 | 09:31 PM
Yeah its a OBD-1 head, or so he says. He didnt say what car its off of
Old Aug 21, 2004 | 11:28 PM
vtecb20coupe's Avatar
B A N N E D
there's a difference in all intake manifolds from obd0 to obd1 to obd2. they all look different and have different vacuum lines, sensors, etc. but all of the b16 manifolds will work with all b16a heads.
Old Sep 3, 2004 | 09:31 PM
Default Re: LS/Vtec Question (vtecb20coupe)
will the vacum lines from a B18b integra fit a B16 head?
Old Sep 17, 2004 | 12:33 PM
95cx's Avatar
Yes you can use various combinations. You just got to know what you are dealing with. My buddy had a OBD-0 b16 mainfold on his b20/vtec with a brand new type r head in his 94 civic coupe and everything worked fine. but he traded up for the JDM ITR manifold. It will work
Old Sep 19, 2004 | 07:51 PM
Default Re: LS/Vtec Question (95cx)
95cx, ur in oconomowoc....im out there a lot at like taco bell, would i ever see u or ur friends around. I know theres 2 blue civics by the grocery store there i see all the time.
Heres a new question though
After doing as much reading as I could about the LS/Vtec, before i receive mine on thursday, i came across a site that said B16 pistons were needed because the LS pistons do not have enough valve cleanance for a B16 head. Is this true or will I be okay running the LS pistons?
Old Sep 20, 2004 | 06:39 AM
95cx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GWInquisitor14 &raquo;</TD></TR><TR><TD CLASS="quote">95cx, ur in oconomowoc....im out there a lot at like taco bell, would i ever see u or ur friends around. I know theres 2 blue civics by the grocery store there i see all the time.
After doing as much reading as I could about the LS/Vtec, before i receive mine on thursday, i came across a site that said B16 pistons were needed because the LS pistons do not have enough valve cleanance for a B16 head. Is this true or will I be okay running the LS pistons? </TD></TR></TABLE>
??? i have a bone stock LS block with LS pistons.... stock SIR2 b16 head. And she's quick.
Taco bell.... i used to work at the grocery store, look for a teal coupe in the lot its turbo¿ If your looking for me stop in at the mobil down the street. Look for some red hatches.
Old Sep 20, 2004 | 12:40 PM
Yeah, next time im out there ill stop by and give ya thanx for the help w/ the swap...or if i need some because i could be doing it this weekend
Old Sep 20, 2004 | 02:45 PM
95cx's Avatar
good deal.
spikey0123
Nov 28, 2011 07:47 AM
lilxchris
Mar 16, 2009 04:18 PM
eg6d15
Dec 31, 2007 08:40 AM
6doorsentra
Dec 6, 2005 08:39 PM
