ls/vtec question
would you call this setup reliable to 9200??
polished and balanced crank, ls shotpeened rods, arp rod bolts, arp headstuds.
want to know if it safe, bottom end wise.ty
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rough_draft »</TD></TR><TR><TD CLASS="quote">would you call this setup reliable to 9200??
want to know if it safe, bottom end wise.ty</TD></TR></TABLE>
It should be save, but while you have to motor apart you might as well replace the rods with something stronger i.e. Eaglel, or Crower rods with your arp rod bolts..... I like to be extra careful but thats only my opinion...... good luck
You need some head work to make it rev that high....
are you changing your valvetrain?
are you adding the gsr girdle?
are you placing a block guard?
are you upgrading your fuel pump?
are you upgrading your injectors?
are you upgrading your fuel management?
some things you should think about......
CRX MASE
37
Nov 10, 2005 04:37 PM
Power Rev Racing
Sep 22, 2004 07:34 PM
