"ls" vtec help
Old Sep 16, 2009 | 09:32 PM
kenlaw13's Avatar
Default "ls" vtec help
what kinda of fuel injectors would i use for my b16 up grade my car is obda 98 integra and does anyone have vtec wiring directions
Old Sep 16, 2009 | 09:46 PM
oodie's Avatar
Default Re: "ls" vtec help
Injectors kinda go with how much power your trying to make NA or Boost. Figure out your power you are trying to get and the right injector will be easy. Search with the Vtec wiring very easy. Many write ups on it.
Old Sep 16, 2009 | 10:12 PM
bigislandc2's Avatar
any stock inj. will be fine. if you tune them then get like 310cc if going N/A. as far as vtec wiring just do a search as Oodie stated. very easy to do...
Old Sep 16, 2009 | 10:23 PM
kenlaw13's Avatar
sorry its a obd2a i have obdo injectors in it now running the "ls" it is hard to find good obd2 injectors will mt obdo injectors give me a problem
Old Sep 16, 2009 | 10:33 PM
oodie's Avatar
Convert to obd1 get aftermarket injectors most use obd 1 injector clips anyway. Get obd 1 ecu install a engine management of some sort and get tuned. That would be the best way to do it.
cherroneballs
Mar 23, 2008 12:10 PM
zexpoweredem2
Honda Civic (2001 - 2005)
Apr 15, 2007 06:31 AM
jansenrw
Nov 19, 2005 08:44 PM
chris@allmotor.net
Oct 19, 2003 04:39 PM
