LS/VTEC Distributor
Old Mar 18, 2005 | 11:07 AM
Speed94's Avatar
Default LS/VTEC Distributor
Does anyone know if the non vtec dizzy will work if I get it to fit? Or will the car just not hit vtec with a non vtec dizzy. I've heard and read different things. Any help would be appreciated.
Old Mar 18, 2005 | 11:10 AM
B20TDC2's Avatar
Default Re: LS/VTEC Distributor (Speed94)
it will work but you have to cut off the inside leg of the dizzy . the leg by the vtec solenoid
Old Mar 18, 2005 | 11:48 AM
Speed94's Avatar
Default Re: LS/VTEC Distributor (B20TDC2)
Are you speaking from experience? I already cut the leg off but just wanted to make sure when Its time to start the car it'll run in vtec with a non vtec dizzy
Old Mar 18, 2005 | 01:50 PM
B20TDC2's Avatar
yeah im running a non vtec dizzy in my car and it works fine. when i went b20/vtec i didnt have a chance to pick one up so i just used the one i already had.
Old Mar 18, 2005 | 04:37 PM
ernald711's Avatar
as previously stated it will work... i have an ls dizzy on my b16 ls/vtec. i machined off the two bottom lobes. works fine as long as you tighten the top bolt real good.
Old Mar 18, 2005 | 06:09 PM
LSvtec03's Avatar
Default Re: LS/VTEC Distributor (ernald711)
ditto. ls distributor on my gsr head.
Old Mar 18, 2005 | 08:17 PM
natesgarage's Avatar
Default Re: LS/VTEC Distributor (LSvtec03)
When i put my motor in the engine bay, my car said, "is it in yet?"
lmao, What leg are you guys talking about.
Old Mar 18, 2005 | 08:19 PM
B20TDC2's Avatar
Default Re: LS/VTEC Distributor (natesgarage)
on the dizzy the leg that the bolt goes in the attach it to the head
Alexpbnj
May 16, 2011 04:36 AM
ED9
Sep 21, 2009 05:11 PM
D-rush08
Sep 7, 2006 10:08 AM
racinategra
Dec 1, 2004 09:53 AM
made in JAPAN
Dec 11, 2002 07:01 AM
