ls vtec with a big problem
Old Dec 1, 2011 | 05:15 PM
b20vteclsintegra's Avatar
Default ls vtec with a big problem
I have a 95 gsr with a lsvtec in it. Im having a problem with the throttle when you step on it over 50% it cuts out and does not go past 3K maybe 4k. But if you easy in to it it will go above that. Im thinking it could be my dizzy??? If someone could give me some ideas of what to start with that would be great. Thanks
Old Dec 2, 2011 | 01:30 AM
arn36's Avatar
Default Re: ls vtec with a big problem
check codes and go from there, does ur vtec work?
Old Dec 2, 2011 | 01:14 PM
No I dont have any codes at all. And no vtec cause im running a p72 Ls ecu
Old Dec 3, 2011 | 12:16 AM
arn36's Avatar
y run a gsr with a ls ecu? ur wasting vtec. lol. id get the correct ecu. did it ever rev correctly?
mouab18c1's Avatar
p72 is a gsr ecu. You need to be running the proper ecu is one of your main issues.
Old Dec 12, 2011 | 03:47 PM
Sorry Im running a p75. Im going to try tonight and run my friends ecu chipped p28 for lsvtec
ericstypeR27
Jan 7, 2009 10:34 PM
94-integra-ls
Mar 23, 2008 04:26 PM
sixtodc4
Jan 11, 2008 02:36 PM
egzo04
Aug 25, 2007 10:46 AM
sk8phaze
May 19, 2003 11:14 AM
