LS VTEC
I have a built LSVTEC going into an 89 civic hatch but Im not sure which wiring harness I will have to use. I have an LS ecu and harness but not sure if it can work with a vtec controller.
Anybody out there know if an LS ecu and a VTEC Controller will be able to conrol vtec. Or do I have to get an OBD1 wiring harness and ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ognuts »</TD></TR><TR><TD CLASS="quote">I have a built LSVTEC going into an 89 civic hatch but Im not sure which wiring harness I will have to use. I have an LS ecu and harness but not sure if it can work with a vtec controller.
Anybody out there know if an LS ecu and a VTEC Controller will be able to conrol vtec. Or do I have to get an OBD1 wiring harness and ecu.</TD></TR></TABLE>
your going to need a obd0 vtec ecu
either a pr3 or pw0 ocu will work
holy hello my post 2 months ago.
yeah u can use it, search one wire vtec. the fuel curves can be corrected by the vafc. red line-> low. i got my gsr ecu for 100.00 shipped. if ur obd2, the plugs for the ls and gsr are the same for 96-98, and u can use the same harness. if not, get an obd1 gsr ecu, and the conversion harness is like 100 bucks. newman has it for 78. dont let anyone tell ya u cant run it with the ls ecu, a gsr is the choice tho.
F5sGsrHatch
Mar 22, 2007 08:06 AM
