ls-vtec
Old Jun 29, 2006 | 09:36 AM
Vitesse's Avatar
Default ls-vtec
Hey everybody,
Now I know this topic has been covered a lot, I also know how to use the search option (to the best of my ability) now If someone could post the complete part(s) list I will need in order to convert my 95 ls to ls/vtec set up that would be very much appreciated.
*IF* it's possible, also a general idea and method of installation I should be approaching; ie. in what order to commence the operation and what problems I should be aware of that I may encounter. [I'm a student, I can't afford to mess this up]
Old Jun 29, 2006 | 09:48 AM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: ls-vtec (Vitesse)
Crap, I have a pretty good parts list at home. If no one helps, I can send you the list.
Old Jun 29, 2006 | 09:51 AM
Vitesse's Avatar
Default Re: ls-vtec (carma_626)
pm'd you!
Old Jun 29, 2006 | 09:56 AM
Vitesse's Avatar
If there is anymore offered experience and knowledge out there, please post.
Thanks
Marc
Old Jun 29, 2006 | 10:03 AM
DBAl's Avatar
http://www.c-speedracing.com/h...c.php
here is a step by step guide on how to do it
Old Jun 29, 2006 | 10:24 AM
Vitesse's Avatar
Default Re: ls-vtec (BigAl1911)
wicked
Old Jun 29, 2006 | 10:28 AM
DC2 Mang's Avatar
here are the parts you will need to build a reliable LSvtec
Required:
Vtec head of your choice
plug the head where the internal vtec oil passage is
external vtec oil line
nipple for the back of the head
dowel pins
Vtec intake manifold and gasket
GSR/ITR head studs
LS head gasket
redline assembly lube
ARP Rod bolts!!
new rod bearings
plasitguage
Vtec ECU
wire vtec for the ecu to the solenoid and pressure signal
Optional:
Vtec pistons
new piston rings (required if you remove your old pistons)
honed block
ITR/GSR oil pump
Vtec water pump
GSR timing belt
you can also remove the crank to have it balanced and mirco polished and then place it back in the block with new main and thrust bearings
Golden eagle and inlinefour.com sell great LS/vtec conversion kits
just make sure all your clearances are within spec and enjoy your new motor
Old Jun 29, 2006 | 10:32 AM
Vitesse's Avatar
Default Re: ls-vtec (DC2 Mang)
Thank's a ton for all the help.. now, how much would I be looking at as an apprx. estimate? Given some of the parts may perhaps be purchased off of egay given they do hold a certain level of quality.
Thanks
Old Jun 29, 2006 | 10:33 AM
Vitesse's Avatar
In dollar value
Old Jun 29, 2006 | 10:42 AM
DC2 Mang's Avatar
I spent around $1500 for everything except money for the LS block and removing the crank
Old Jun 29, 2006 | 11:03 AM
Vitesse's Avatar
would you say if done right... better reliability than a turbo ste up @ 7 lbs on stock internals?
Old Jun 29, 2006 | 11:31 AM
DC2 Mang's Avatar
rings seated fine, i built if for all motor and reved it to 8.5k easy
for boos I would use the stock LS pistons with a fresh hone and new rings and you will be fine
hung_kuen
Northwest
Jul 9, 2008 08:43 PM
Jeffrey D.
Apr 26, 2008 11:59 AM
KangTa
Jun 12, 2005 03:02 PM
Turbotype
Feb 21, 2005 03:04 PM
lj420p
Jan 25, 2005 02:10 AM
