ls/vtec
i have b18b with stock internals and i was seeing if anyone on here has done a ls/vtec setup on stock internals and how it went how long it lasted, and did it make a big differance putting a vtec head on and opions
on doing the head swap was it worth it thanks and yes i know i should search
Just to let you know people are going to give you alot of **** for asking this question. Im sure there are about a million threds on this subject. So like every one else is going to say SEARCH FOR IT FIRST.
LS/VTEC is not reliable even though properly tune it will haul ***. It will only give you major headaches. A buddy of mine has LS/VTEC it was fine for 10k miles but now it is starting to leak oil. Trust me LS/VTEC will not last that long. Stick to GSR motors
, that is the best bet right now.
Don't listen to the guy above...If you done your search correct you'll see the things that need to be done, so I will not touch that. I will simply answer what was stated on your post with my expierance! I have a 99 LS, that had 100k on it about 2yrs ago, I wanted more power so I did the LSV..I did gain noticable HP with stock LS internals. But I would upgrade your block, rods and crank balancing, arp bolts should be good. I now have 150K on my LS block and the head has about 120k. and runs really good no problems at all, normal maintance done. I used an ITR head, that doesn't you have to, I am sure a B16, a GSR is just as fine...GL on your swap...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones »</TD></TR><TR><TD CLASS="quote">I now have 150K on my LS block and the head has about 120k. and runs really good no problems at all, normal maintance done. I used an ITR head, that doesn't you have to, I am sure a B16, a GSR is just as fine...GL on your swap...</TD></TR></TABLE>
BTW, replacing your head and modifying the car beyond its stock specs (ie, you put a new head on with god knows what else) is not "normal maintence". Whats up with the ls/vtec questions.....i mean, its like the most covered topic ever.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones »</TD></TR><TR><TD CLASS="quote">Don't listen to the guy above...If you done your search correct you'll see the things that need to be done, so I will not touch that. I will simply answer what was stated on your post with my expierance! I have a 99 LS, that had 100k on it about 2yrs ago, I wanted more power so I did the LSV..I did gain noticable HP with stock LS internals. But I would upgrade your block, rods and crank balancing, arp bolts should be good. I now have 150K on my LS block and the head has about 120k. and runs really good no problems at all, normal maintance done. I used an ITR head, that doesn't you have to, I am sure a B16, a GSR is just as fine...GL on your swap...</TD></TR></TABLE>
good post
good post
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">BTW, replacing your head and modifying the car beyond its stock specs (ie, you put a new head on with god knows what else) is not "normal maintence". Whats up with the ls/vtec questions.....i mean, its like the most covered topic ever.</TD></TR></TABLE>
it seems pretty obvious that he meant normal maintence as far as oil changes ect.... changing your head to a vtec head is not and will never be maintence its a modification.
Yea, i get that, but Im saying that he's saying that the block and head have XXXXXX miles on them and are still running great in the ls/vtec and Im saying that even if the head/block do have that many miles on them, it doesnt really count if you put a new head gasket on (with the ls/vtec), replaced most of the seals, etc.....ie, crap that isnt normal maintence and is more so done with major engine work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91cleancrxsi »</TD></TR><TR><TD CLASS="quote">i have b18b with stock internals and i was seeing if anyone on here has done a ls/vtec setup on stock internals and how it went how long it lasted, and did it make a big differance putting a vtec head on and opions
on doing the head swap was it worth it thanks and yes i know i should search </TD></TR></TABLE>
i been having my ls/v for a year now. runs fine.
do it right the first time and ur set.
Kangolbrand
Dec 24, 2005 07:01 PM
RSNTEKRA
Oct 3, 2005 10:58 AM
