LS SWAP
nope everything isnt plug and play, you need to use your existing injectors, distributor and engine wiring harness. you cant use the tranny without mount modification. you mounts will be fine if you use the b18b engine and your cable tranny. you will also need to re-route vaccuum lines. goodluck
jayjona8732
12
May 25, 2010 02:17 PM
stackz
Aug 30, 2006 10:04 AM
