LS owners, ever encounter this problem?
Old May 11, 2004 | 11:08 AM
khmboostedeh2's Avatar
Default LS owners, ever encounter this problem?
i have this problem, its a 1994 b18b engine. the engine starts and revs fine, and the tranny goes into gear, yet the car wil not move nor stall if i leave it in gear with the clutch off. the tricky thing is that the speedometer will rise, (up to 20mph in neutral, got it to 60 in 5th but i didnt mash teh gas). i recently put this motor in my eg and i did change the clutch. anyone encounter this problem before? im dying to fix it but i dont knwo what to rip the transmission off yet.
Old May 11, 2004 | 11:14 AM
nickgmiller04's Avatar
Default Re: LS owners, ever encounter this problem? (Jeterkm02)
sounds like something is wrong w/ the clutch/tranny. something is not connected if it wont stall when left in gear. i have no idea tho
SuzukaBlueAP2's Avatar
Never encountered that. I've done approx. 3 clutch installs now, and never had that. Sounds like improper clutch installation though.
Edit, I just had an epiphany...lol...
what if the slave cylinder was not attached to the tranny? I've never tried to detach it and see what would happen, so I don't know for sure.
Just go over everything you did, check the exterior of everything and make sure all is connected/bolted together. If it is, then your problem lies inside the bell housing.
Old May 11, 2004 | 11:21 AM
Default Re: LS owners, ever encounter this problem? (ScreaminTeg)
well since the spedometer is reading something, anda speedometer works off the final drive, its my assumption that the clutch is fine and that the drivetrain is screwed up, therefore providing no resistance whatsoever to stall the engine. does that make sense?
Old May 11, 2004 | 11:56 AM
MatHadder's Avatar
did you remember to install the axles?
Old May 11, 2004 | 12:04 PM
Audi A4's Avatar
Default Re: LS owners, ever encounter this problem? (MatHadder)
yeah make sure the axels are in all the way
Old May 11, 2004 | 12:17 PM
Default Re: LS owners, ever encounter this problem? (DRAG lll INTEGRA)
haha of course i remembered to install them. ill double check that they are in all the way.
Old May 11, 2004 | 12:33 PM
Audi A4's Avatar
yeah make sure there pooped in allll the way
Old May 11, 2004 | 12:41 PM
ok i just went and checked... the passenger side axle seems like its out a little, the drivers side is in all the way. heres pics.
passengers:
http://www.angelfire.com/empire/fnc/DSC00023.JPG
drivers:
http://www.angelfire.com/empire/fnc/DSC00024.JPG
so when i checked, i started to mess around with the axles. with the car on... i jiggled the axle and when i pulled it out the slightest bit it turned. i dont know what to think anymore. any suggestions?
:edit: i guess angelfire doesnt allow links... copy and paste if u can please.
Modified by Jeterkm02 at 5:27 PM 5/11/2004
Old May 11, 2004 | 12:51 PM
FlaN.'s Avatar
those pics were horrible
Old May 11, 2004 | 01:32 PM
Default Re: LS owners, ever encounter this problem? (FlaN.)
anyone help?
Old May 11, 2004 | 02:38 PM
jdmkrazie's Avatar
i've been through something like that before.. its either bad axles or somethings wrong with your tranny. but most likely its your tranny going bad or is bad.
have you ever used that tranny before and if so how long?
Old May 11, 2004 | 02:43 PM
mikemcberty's Avatar
sounds bad, but it sounds like a tranny problem to me, but i'm no expert.
Old May 11, 2004 | 03:04 PM
Default Re: LS owners, ever encounter this problem? (jdmkrazie)
i bought this complete swap from Hmotors online, i finished puttin it in yesterday... and ive been stuck with this problem since then.
update on teh situation: i took the passenger side axle out, it was all worn out on the tip after the C ring, i filed it down so it would retain its original shape, the axle fit into the transmission better. i started the car, both wheels now spin, but they are absolutely torqueless in first gear, i can easily stop the wheels from spinning. any ideas whats a matter?
Old May 11, 2004 | 03:06 PM
Audi A4's Avatar
and the rest of the gears
Old May 11, 2004 | 08:07 PM
jdmkrazie's Avatar
its the transmission man... the internals are busted. thats what i'ma have to say it is... go to a transmission shop and ask and i'm almost 100% sure that they'll tell you it has something to do with the inside of the tranny
Old May 11, 2004 | 08:38 PM
boredracer408's Avatar
Default Re: (mikemcberty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikemcberty &raquo;</TD></TR><TR><TD CLASS="quote">sounds bad, but it sounds like a tranny problem to me, but i'm no expert.</TD></TR></TABLE>
Old May 11, 2004 | 09:46 PM
FunkDaddyFresh's Avatar
Default Re: (boredracer408)
no i have not
Old May 11, 2004 | 09:50 PM
Rod.'s Avatar
Default Re: (FunkDaddyFresh)
Had 2 ls's and never encountered that problem
Old May 12, 2004 | 03:32 AM
shyboy817's Avatar
never happened to me
turbojohnny
Sep 30, 2009 09:18 AM
withemptyeyes
Sep 18, 2007 05:47 PM
mawkiemarc
Aug 1, 2005 08:41 PM
mr_mbuna
Oct 5, 2002 08:59 PM
phatintegra
Mar 21, 2002 08:46 AM
