Ls issue
trading my ek for an ls integra its a 98 with a 95 motor in it i asked if he did an obd change and he said no running obd2 ecu has check engine light and idles ok but when driving then you stop it surges 2 or 3 times any ideas any ideas on what needs to be done to get it right
I would do the opposite and use a jumper harness and run an OBD1 P75. Figure $100 total as the ecus are about $50 and the jumper harnesses are about the same. Good luck!
