Lowering question??
Old Jun 22, 2002 | 02:03 PM
. M i c h a e l's Avatar
dotmichael to you
Default Lowering question??
Modified by . M i c h a e l at 5:32 AM 10/31/2005
Old Jun 22, 2002 | 02:13 PM
mattL's Avatar
Default Re: Lowering question?? (AznBlitz)
is the brake system working well? make sure your ebrake is all the way down, if its up just one notch the ABS light comes on
Old Jun 22, 2002 | 02:21 PM
Anthony K's Avatar
New User
Aren't there ABS sensors that you could've damaged during the installation?
Old Jun 22, 2002 | 02:48 PM
mattL's Avatar
reset your ECU and see if it comes back on, maybe it was triggered during the install?
Old Jun 22, 2002 | 06:11 PM
Tanner's Avatar
New User
Disconnect the battery or pull the ECU fuse under the hood for a minute or so..
Old Jun 22, 2002 | 06:29 PM
Tanner's Avatar
New User
The fuse is under the hood in the fuse box, and there is a fuse diagram on the lid of the box... Or disconnect just one cable.. there has to be either power or ground without one the other doesnt work..
Old Jun 22, 2002 | 06:30 PM
Tanner's Avatar
New User
Default Re: Lowering question?? (Tanner)
Ohh and I wouldnt worry about Acura.. they wont be able to tell...
Old Jun 23, 2002 | 06:10 AM
Tanner's Avatar
New User
Yeah hook the cable up or stick the fuse in..
As for the ABS sensor, I have no idea on price, and I am not at home right now to search links I have for Acura parts..
If I were you and this doesnt work...I would go to Acura and tell them to run a diagnostics on it and if it is the sensor I would buy a Helms Manual and put it in myself.... but thats me
Old Jun 23, 2002 | 06:25 AM
rsx03's Avatar
Wassup Wil, it's John.
Hey man who did your installation for you, they may have most lilkely damaged the rear abs lines because I just did my springs last weekend and i found it alittle tricky to remove the shock/spring asssmebly while pulling the abs line outta the way so it doesnt get nicked or tear somehow.
bring it back and complain, they'll most likely and hopefully troubleshoot the problem and fix it for ya..Just dont wait to long to go back or they will blaim it on you and say you did something
coregis
Jun 16, 2009 10:20 PM
ramz7887
Dec 4, 2005 01:44 AM
ArchAngel Sabastian
Jan 20, 2003 04:49 PM
Crono139
Jan 6, 2003 11:26 AM
Norcalstoppy
Aug 27, 2002 09:54 AM
