Lower Control Arm Help !!
Old Mar 17, 2006 | 03:16 PM
GsRTegKid's Avatar
Default Lower Control Arm Help !!
How Hard Is It To Change A Lower Control Arm on a 96 integ and what kinda of tools would I need..I was Also Wondering what is the farest model I can get if they dont have a 96 lower Control arm. would anything from 94-01 work or would it have to be in a 94-96 mods..Kinda new at this.thanks for the help everyone..
Old Mar 17, 2006 | 03:25 PM
bg-33p's Avatar
Default Re: Lower Control Arm Help !! (GsRTegKid)
Bump, need to know this too
Old Mar 17, 2006 | 06:38 PM
nickG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsRTegKid &raquo;</TD></TR><TR><TD CLASS="quote">How Hard Is It To Change A Lower Control Arm on a 96 integ and what kinda of tools would I need..I was Also Wondering what is the farest model I can get if they dont have a 96 lower Control arm. would anything from 94-01 work or would it have to be in a 94-96 mods..Kinda new at this.thanks for the help everyone..</TD></TR></TABLE>
if its the rear lca you shouldnt need more than basic metric hand tools..its not that hard....
unless youve never touched them before, the bolts may have seized up on you and will break off..PITA..
and 94-01 rear lcas are all the same
Old Mar 18, 2006 | 04:30 AM
GsRTegKid's Avatar
Default Re: Lower Control Arm Help !! (nickG)
its the passenger side and would the tools be any diff?
Old Mar 18, 2006 | 04:41 AM
AllMotorDan's Avatar
its easy if your bolts will come lose, 3 bolts and 1 for the sway bar. i think they are 14mm's, you need a jack also and maybe another smaller jack and hammer to help you keep the new lca lined up with the bolts while you screw it in.
Old Mar 18, 2006 | 05:01 AM
teggy182's Avatar
Default Re: (SpoonSirG)
when i changed my sus. both lcs bolts broke in the rear. it was a real pain i sugest using liquid wrench or wd-40. at least 2 night before starting the job, and front are easy.
Old Mar 18, 2006 | 05:02 AM
teggy182's Avatar
o and id suggest using air tools
Old Mar 19, 2006 | 08:30 AM
dustin528's Avatar
When i took my lca's off, I was only able to get three bolts off without breaking them; IT SUCKED. The car was from the north and I will never buy a northern car again. This is why I like living in the south, the rust isn't bad.
adam squared
Jan 15, 2010 12:24 PM
WarpedSportzKid
May 23, 2006 05:30 PM
markwitdada9
Jan 31, 2006 05:15 PM
CivicHb04
Dec 23, 2003 09:56 AM
