low mpg
Old Feb 14, 2011 | 08:31 PM
Killspeed93's Avatar
Default low mpg
as of lately my gsr has been running strange and sucking up a lot of gas. im doing an oil change next week, and replacing a valve cover gasket. theres a check engine light and i had it checked out and its that i need a new cat... but i dont think that should affect the mpg that much on it but i could be wrong.. any suggestions on what i should check and or replace?
Old Feb 14, 2011 | 10:38 PM
igorka_91's Avatar
Default Re: low mpg
If ure O2 sensor is bad. It will cause ure cat to go out from running to rich and give you bad gas millege.
Old Feb 14, 2011 | 11:37 PM
turbozc03's Avatar
Default Re: low mpg
^^^ x2
Old Feb 15, 2011 | 12:50 AM
megawrench's Avatar
Default Re: low mpg
your cat could be clogged, feel exhaust coming out of muffler with your hand, do a general tune up if needed, especially fuel filter.
Old Feb 15, 2011 | 07:54 AM
Yablonski135's Avatar
Default Re: low mpg
I'm having the same problem with a 2001 GSR. Getting about 250mi/tank. Should be easily over 300.
Old Feb 15, 2011 | 08:04 PM
Default Re: low mpg
if the cat is to be clogged how can u clean it out or is it just better to replace because theyre not too cheap i know that much or is it something you can do out of your garage
edgar94
Dec 16, 2013 12:06 AM
EKcivic1230
Apr 12, 2005 09:07 AM
LS AnGeL
Jan 16, 2004 12:53 PM
All Motor Speed
Aug 20, 2003 07:34 PM
d8168055
Feb 28, 2003 09:15 AM
