low idle problem...SOLVED
Old Jun 15, 2002 | 11:28 PM
jetdriven's Avatar
Default low idle problem...SOLVED
when I changed the timing belt I installed the exhaust camshaft one tooth retarded. Too much valve overlap at idle and no vacuum. it idled at 500 rpm. RUNS PERFECT NOW. Lesson learned, throw away the haynes manual! Do not even attempt to service your car without a HELMS!!!
Old Jun 16, 2002 | 08:18 AM
Regular Series's Avatar
Default Re: low idle problem...SOLVED (jetdriven)
Duly noted.
Old Jun 17, 2002 | 06:42 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
So was it a mistake of yours that the exhaust cam was one tooth off, or was it mis-information in the Haynes manual?
Old Jun 17, 2002 | 07:11 AM
MikeSarr_GSR's Avatar
Default Re: low idle problem...SOLVED (PatrickGSR94)
I have a haynes manual and they have complete instructions about
indexing the camshafts... sounds like someone is trying to get out
of a mistake... I will admit the haynes is no where near the depth
of the helms or acura shop manual for our cars.
just say it once to get the feel of it:
"I fu**ed up!"
been there before but on the 3-4 shift and went to second... can we
say fully built valvetrain?> hehe
[Modified by MikeSarr_GSR, 4:13 PM 6/17/2002]
Old Jun 17, 2002 | 12:58 PM
jetdriven's Avatar
Default Re: low idle problem...SOLVED (MikeSarr_GSR)
My mistake..BUT the haynes manual does not mention driving 5.0MM pin punches into the front cam bearing cap to index them to TDC. All haynes mentioned was to line up index marks on cams with mark on the back timing cover. The back timing cover was warped from heat and the mark was deformed. top it all off the "up" arrows arent perfectly straight up when I aligned the marks. So I best guessed it and it started right up. only clue was lack of power below 2,000 RPM and low idle. Funny thing is the damn thing still got 30 MPG on the freeway! Also, haynes manual does not even MENTION how to properly rotate crank gear (past TDC 3 teeth on cam) to set correct tension on the belt. Do not waste your time with a haynes manual to change a cam belt... Other people have posted this problem and this might help them.
Old Jun 17, 2002 | 02:39 PM
obd2gsr's Avatar
89ED
11
Sep 14, 2013 10:53 PM
hmtcrxsir
20
Jan 28, 2010 06:33 AM
FUP23
13
Sep 3, 2002 06:22 AM
SleepinGSR
Feb 18, 2002 02:02 AM
