low compression
Old Sep 27, 2008 | 08:30 AM
GSR15's Avatar
Default low compression
low compression in cylinder #3 about 60 psi. time to rebuild??? car still runs strong. no lack of power!
Old Sep 27, 2008 | 09:35 AM
letsdrive's Avatar
haha... if its that low it cant be running strong! did you do the test correctly w/ the accelrator at WOT and crank till no more pressure builds? do you burn any oil? is this the first time you tested it? maybe you're used to the lack of power.
Old Sep 27, 2008 | 02:28 PM
GSR15's Avatar
Default Re: (letsdrive)
umm i took it to the dealer to have this problem solve i was getting a check engine light, went to shucks and checked it there, sayed cylinder 3 misfire so then i took to the dealer then they sayed cylinder 3 is no good need to rebuild and the cost of that was gonna b $2,100 i was like wtf. and secondly when i bought the car it had 54,000 miles on it with no problems. its still running like when i bought it! just that once in awhile the check engine comes on, and when fully warmed up it sounds kinda like a diesel from the exhaust, and idles at like 400.
FlipMode01
Honda CR-V & Element
Nov 3, 2016 08:32 AM
Tyteg
May 16, 2007 07:30 AM
jvtec95
Apr 18, 2007 08:54 PM
2000civic-Si
12
Aug 29, 2005 11:47 AM
Ochux
Nov 8, 2001 12:52 PM
