low beams
9005/HB3 if your going to be doing the conversion. If not 9006/HB4, Sorry if i'm confusing you. But if you just want a stock replacment bulb its a 9006. But alot of people put the 9005's in with slight modification.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8gsr_teg »</TD></TR><TR><TD CLASS="quote">i know 9006 are for low beams and 9005 are for high beams
fixed
</TD></TR></TABLE>fixed
you can use the 9005 as a type of "retro fit" and should have no problems.
there are a few threads that tell you how to do this, it is pretty simple. jsut search for "9005 9006" and make sure you search archived and you should find some.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8gsr_teg »</TD></TR><TR><TD CLASS="quote">i think 9006 are for low beams and 9005 are for high beams
Check my signature for a 9005conversion howto I wrote a while back. I'm stickin with it for now since I don't feel like paying for HIDs. It seems to work well, but I do have to replace the bulbs once a year or so, it doesn't help that i'm using silverstars though.
