lost wheel lock key :(
Old Feb 23, 2006 | 06:21 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default lost wheel lock key :(
So I seem to have misplaced my OEM Acura locking lug key. I probably torqued the lug nuts last time when I had to swap wheels and left the thing sitting on the last one and drove off.
So yeah these are the OEM-style locking lugs, round on the outside with a squiggly shape cut out on the inside. What are my options for getting these things off? I don't want to be stuck with a flat tire and no key.
I got one of those Gator Grip sockets, it was a POS of course. It wasn't even big enough to fit over the locking lug.
I could hammer on a slightly smaller socket, but I'm guessing I would end up having to buy 4 sockets, one for each lug as I probably wouldn't be able to get the socket off the lug once I got it off the wheel.
Any other ideas?
Old Feb 23, 2006 | 06:23 PM
gsrwpower's Avatar
Default Re: lost wheel lock key :( (PatrickGSR94)
Thats easy. Just look at the part # on your wheel lock box and call the acura dealer close to you and get the same exact one ordered.
Old Feb 23, 2006 | 06:24 PM
Community Builder
well see that's the problem... I MIGHT still have the box but I don't know. It's been nearly 5 years since I bought the car and the locks.
Old Feb 23, 2006 | 06:25 PM
foam's Avatar
Default Re: (PatrickGSR94)
Can't you take it to Acura and they could probably help ya?
Old Feb 23, 2006 | 06:26 PM
gsrwpower's Avatar
Want the part #. I got my wheel lock box in my integra. I will leave you a post relpy tomorrow and you can order the key.
Old Feb 23, 2006 | 06:34 PM
CNSK's Avatar
Default Re: (integradude98)
you can take it to your local shop and ask if they can use a power tool to removed lug nut. When my dad bought his truck the owner didnt have the key and I took the car to this shop and they removed it. They used some socket, pound it in and used an air compressor to removed it but you can kiss the nuts goodbye.
Old Feb 23, 2006 | 06:35 PM
Dogginator's Avatar
Daisy... Daisy...
Weld normal wheel nuts to the locks and unscrew them.
Old Feb 23, 2006 | 06:41 PM
nickG's Avatar
Default Re: (CNSK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CNSK &raquo;</TD></TR><TR><TD CLASS="quote">you can take it to your local shop and ask if they can use a power tool to removed lug nut. When my dad bought his truck the owner didnt have the key and I took the car to this shop and they removed it. They used some socket, pound it in and used an air compressor to removed it but you can kiss the nuts goodbye. </TD></TR></TABLE>
werd..
any wheel shop can take off wheel locks...but if the hammer on a socket method doesnt work, they use an air chisel like tool...at least we did at the shop i worked at...no guarantee on the wheels either...
try and find your key or get another
Old Feb 23, 2006 | 07:16 PM
brandons 95ls's Avatar
Default Re: (nickG)
most shops have a special socket to take them off
Old Feb 23, 2006 | 08:46 PM
jdm tommy's Avatar
i also lost my key what i did was hammered a socket that almost fit over the lock then took it out with a breaker bar
Old Feb 23, 2006 | 09:08 PM
IN VTEC's Avatar
Call your local and regional Acura dealerships until you find one with a master wheel lock key set. Have them remove them and put your non-locking lug nuts back on until you can get another set.
Modified by IN VTEC at 12:20 AM 2/24/2006
Old Feb 23, 2006 | 09:13 PM
shiux's Avatar
i had to bring mine to a shop and they used one of those air compressor things to take mine off. had to buy new lug nuts. but w/e
Old Feb 23, 2006 | 09:32 PM
cm zak's Avatar
Hammer on a impact bit and use a air wrench, then pry them out of the bit and repeat.
You'll probably need new lugs after this. But you lost the lug key anyway right?
Old Feb 23, 2006 | 11:23 PM
1337whp's Avatar
Default Re: lost wheel lock key :( (jdm tommy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm tommy &raquo;</TD></TR><TR><TD CLASS="quote">i also lost my key what i did was hammered a socket that almost fit over the lock then took it out with a breaker bar</TD></TR></TABLE>
1337
Old Feb 23, 2006 | 11:43 PM
integra3586's Avatar
Default Re: lost wheel lock key :( (1337whp)
i thought he said he has the key number? if so the dealer will be able to order a new wheel lock key
Old Feb 24, 2006 | 06:00 AM
Community Builder
I might still have the locking lugs package somewhere but I don't know... it might be in my parents' attic. I bought them nearly 5 years ago.
And some 'tard tried to steal my wheels shortly after getting the locks, and ran off with 3 of my original lug nuts and left only the lock on one wheel. So I had to use 3 of my 4 spare lug nuts, and now only have 1 spare remaining.
Old Feb 24, 2006 | 11:26 AM
Typeron's Avatar
I had the same thing happen to me. I had it at a mechanic's shop, and they tried to take it off with i'm not sure what, and scuffed up one of my rims. But I took it to an American Tire Depot near my work and they had those things off in 20 minutes without any marks whatsoever. I would suggest taking it to a tire shop, and make sure they have the special equipment needed to take it off.
Old Feb 24, 2006 | 11:29 AM
Mordeki's Avatar
Abusing my rights one day at a time.
Default Re: (Typeron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Typeron &raquo;</TD></TR><TR><TD CLASS="quote">I had the same thing happen to me. I had it at a mechanic's shop, and they tried to take it off with i'm not sure what, and scuffed up one of my rims. But I took it to an American Tire Depot near my work and they had those things off in 20 minutes without any marks whatsoever. I would suggest taking it to a tire shop, and make sure they have the special equipment needed to take it off. </TD></TR></TABLE>
They do it everyday
Old Feb 24, 2006 | 12:04 PM
lojackgsr's Avatar
Hammer a 19MM socket on it, really hard. avoid hitting the wheel obviously, u will then be able to take the lock off, i did this to each wheel on my 98 gsr, stock OEM locking lugs, worked perfect, u might need multiple sockets if u have trouble getting the lock back out of the socket after u get it off.
Old Feb 24, 2006 | 12:43 PM
Default Re: (lojackgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lojackgsr &raquo;</TD></TR><TR><TD CLASS="quote">Hammer a 19MM socket on it, really hard. avoid hitting the wheel obviously, u will then be able to take the lock off, i did this to each wheel on my 98 gsr, stock OEM locking lugs, worked perfect, u might need multiple sockets if u have trouble getting the lock back out of the socket after u get it off.</TD></TR></TABLE>
to get the lock out of the socket, get a hammer and hit the side of the socket... HARD it will pop out, it may *** up ur socket too
Old Feb 24, 2006 | 01:37 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: (B18B-SC)
impact wrench that bit ch
Old Feb 24, 2006 | 03:22 PM
iheartDc2's Avatar
ouch
Old Feb 24, 2006 | 03:45 PM
vawn69's Avatar
take it to your acura dealership...whether five years or not they will have a set there to match...usually they have the keys to all of wheel locks regardless of year...they will find which key it is and if you want order a new key and locks with it........easy...i work at a dealership
Old Feb 24, 2006 | 04:25 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: lost wheel lock key :( (vawn69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Call your local and regional Acura dealerships until you find one with a master wheel lock key set. Have them remove them and put your non-locking lug nuts back on until you can get another set.</TD></TR></TABLE>
Ding ding ding! We have a winner!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vawn69 &raquo;</TD></TR><TR><TD CLASS="quote">take it to your acura dealership...whether five years or not they will have a set there to match...usually they have the keys to all of wheel locks regardless of year...they will find which key it is and if you want order a new key and locks with it........easy...i work at a dealership</TD></TR></TABLE>
Ding ding ding! Another winner!
That will get the locks off. When you're at the dealership, you can buy the spare lug nuts you need for around 4-5 bucks each. Or, stop by Autozone on your way to the dealer and get them for $1.19 each, part number 99913. Make sure you ask for lug nuts with the ball-shaped seating area that you'll need for all Hondas/Acuras, and the acorn type (short stubbly lug nuts).
If you want to re-use the same locks later, if you registered your set with McGard when you bought them (there's a registration card to mail in), you can send in to McGard to buy a new key for around ten bucks. Or, you can buy an entire new set of locks with a new key. BTW, most dealers charge around forty bucks for the set of locks. I just priced a set for a 2004 Civic in another topic and found that they are only $16 at San Leandro Honda. They should fit any Honda/Acura wheels, and come with the ball-shaped seating area you need.
Old Feb 24, 2006 | 06:06 PM
yee SERIOUS's Avatar
yeah just take it to the dealership. when i lost mine i just went to work (for those who are slow minded, honda ) and told the dispatcher. he gave me the sets of locks (there was 4 ****ing sets of 8) and i found the right key. of course i was the laugh of the day, but other then that i just had them order it. and it was 8 or 14 bucks, employee price lmk if u need me to order u one.
