looking for the most comfortable coilover and strut setup
Old Jan 7, 2002 | 08:00 PM
mon2mon2's Avatar
Default looking for the most comfortable coilover and strut setup
i think i have it down to : Ground Control coilovers and KYB AGX or GR2
my question is : does the GR2 have the same ride quality with the SOFTEST setting of the AGX....??? if so, then i;m better off just buying the GR2's cause they're less expensive. -- i'm only interested in the comfort of the ride, not necessarilly the stiffness...
any comments??? or any other set-up i should consider???
anybody.........thanks.............
Old Jan 8, 2002 | 06:58 AM
deviant94ex's Avatar
New User
Default Re: looking for the most comfortable coilover and strut setup (mon2mon2)
i used to own a 1987 audi 5000cs quattro and i had a set of the kyb gr2's and intrax 1.75" lowering springs. it definitely increased the cornering ability as well as keeping body roll more in check. the ride was slightly rougher than stock but still very comfortable. the only suggestion that i would have is to make sure that the whichever shocks you get that the spring rates of the GC's arent too high. this can cause premature failure of the shocks. i would probably go with the agx's and the regular ground controls. i have heard stories of even the agx's failing after a while with custom spring rate GC's. good luck.
CHRIS
pcteck
Suspension & Brakes
36
Dec 9, 2013 03:38 AM
Eg6Matt
Feb 14, 2010 08:31 PM
karubin
28
Aug 26, 2009 07:51 AM
civicsareslow
Suspension & Brakes
20
May 17, 2006 07:35 PM
-Whitey-
17
Dec 5, 2002 10:44 PM
