location of motor code stamp?
If you are looking straight down at the valve cover, look slightly further down, and you will see your header/exhaust manifold coming out of the head, look to the left of that, and a little below where the head meets the block, you should see a flat part of the block with some stamping on it, that is your block code. It should say B16A2 or B18C1 or some 5 digit code if it's a USDM motor.
It is directly under the word "THIS" :
SandstormGT
10
Nov 18, 2007 08:53 AM
peterboroughkid
Jun 13, 2003 12:44 PM
