Link Engine Management System
I"m now a distributor for the Link Engine Management System. This is a fully programable EMS, similar to the new AEM EMS. Here are a list of some of the
features:
Custom Design
Invisible installation as the Link system is inside the factory ECU enclosure.
Custom Software
Special programs e.g. Antilag etc. available for additional charge. Also will allow up to 10psi of boost with stock sensors. (If you want to go higher boost
special sensor sold seperatly)
Dedicated Software
Plug-In systems have software written specifically for each application with good safe settings as a starting point for further setup and tuning. Windows
based program.
Discrete & Unobtrusive
Easily removed without trace. Mounts to stock ecu spot without any modifications.
Factory Sensors
Uses 100% factory sensors. Ease of system installation and vehicle servicing.
Factory Wiring
No wiring modifications necessary. Plug and Play.
Launch Control
Perfect rpm launch! Set a rpm level of your desire for staging launches. And capable of full throtle shifting.
Plug-In
Fast reliable installation, car integrity is retained. Sometimes the complete installation can take place without lifting the bonnet. Uses 100% factory
sensors.
Rev Controls
Lower, raise, or remove your rpm limits, and VTEC engagement point.
Tuning
Can use the Remote Tuning Module, PC Link Laptop software, Print Link, Serial Link, or the Data Trap.
Data Logging
Records MAP, TPS, RPM, IGN, FUEL, Knock levels, Exhaust Temp, Inlet Air Temp, VTEC on/off, many more...
RPM level switch
Built in shift light to your check engine light. Can hotwire to external auxiliary shift light or covert to NOS rpm activation.
This is a list of most the features of the unit. This unit is avaliable for 92-01 Integras and 92-00 Civics as a plug and play replacement. THe price of the
unit is $1021. If there are any questions or comments please email me at mugenintegra16@yahoo.com or PM me. I will be away on vacation till friday
though so i'll answer any questions when i come back thanks you.
Herminator
Dec 27, 2001 07:12 PM
