Leaky trunk
Old Mar 10, 2003 | 08:02 PM
Jolf's Avatar
Default Leaky trunk
The trunk leaks water every time it rains or the car is washed. Car in question is a 94 LS 4 door.
I'm guessing it is just the weather stripping and needs to be replaced. Anyone else have this problem or know for sure if it is the weather stripping? DOn't want to spend money and not have the problem fixed.
TIA
Old Mar 10, 2003 | 08:22 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Leaky trunk (Jolf)
Your problem is the gasket in the tailights leaking. Trust me.
There is a big thread on it somewhere here on HT. Search for it.
EDIT: Couldn't find the post, but it's here somewhere. I had that problem, and so did many others here. Take out the taillights and examine the gasket. Your options are to put it back on with some silicone sealant and put the taillight back on tightly to seal the gaskets.
Your second choice is to get these:
https://honda-tech.com/zerothread?id=378920
If you found that post I was talking about, you'll see that OEM gaskets from Acura are crazy expensive. Pick these up for $10 or so if you need them.
Good luck. Get them fixed before you get a big rainstorm and the water starts going into the seating area.
[Modified by shamoo, 12:25 AM 3/11/2003]
Old Mar 10, 2003 | 08:30 PM
jabroni95gsr's Avatar
Default Re: Leaky trunk (shamoo)
I too have this problem but i'm not sure its going to be the taillight gaskets...I will be investigating tomorrow. My sedan seems to have a wet carpet trunk on the drivers side, in the little cubby hole that is on each side. i'm curious to see if it is the taillight gaskets because it doesn't seem to get wet near the taillights...its further forward.
Old Mar 10, 2003 | 08:32 PM
Br1t1shguy's Avatar
Default Re: Leaky trunk (jabroni95gsr)
Yes, when I had my 4 door integra it had wet carpet and water in those exact same spots. It doesnt look like its coming from the lights, but trust me IT IS. If you take them out you'll find the gaskets are all wet and probably ripped. Just get some clear silicone adhesive/sealent, go nuts with it all over the gasket/light/holes etc and 10 bucks says no more leak.
Old Mar 10, 2003 | 08:35 PM
Jolf's Avatar
Default Re: Leaky trunk (Br1t1shguy)
Haha, search owns me. I'll check the tail light gaskets out later this week and bu any that need to be replaced.
Old Mar 11, 2003 | 04:28 AM
JimBlake's Avatar
It could also be the sunroof drain hoses, if they're not plugged in where they belong. Or maybe the drain from the bottom of the antenna motor. Shake some talcum powder all over back there, then spray outside with a garden hose. Wherever its leaking you'll see tracks in the powder.
Then you'll have to clean up the powder...
vtecdc4
Sep 21, 2010 12:43 PM
jweezy225
Aug 22, 2007 05:28 PM
dokesdc2
Jan 1, 2005 01:13 PM
Heisdan
Jul 2, 2003 06:47 PM
Phat Corolla
Dec 18, 2001 03:35 PM
