Leaking clutch fitting
Old Nov 3, 2001 | 06:27 PM
Rain_man's Avatar
New User
Default Leaking clutch fitting
I just changed my master and slave clutch cylinder today, and as I took it out for a drive, I noticed that if I held the clutch pedal to the floor long enough it wouldn't come back up and I would have to pull it back up. After being pulled back up it was normal again. If I clutched in and out fairly quickly that wouldn't happen as well.
I felt around the fittings for the two cylinders and found that they were leaking, so I guess this is the source of my problem. What can I use to stop the leaking? Keep in mind I'm not using the stock clutch hoses, but rather a SS braided line with fittings.
Thanks!
mint95gsr
Oct 10, 2013 01:17 PM
coconutsoldier
Nov 19, 2004 11:21 PM
Rain_man
Nov 3, 2001 07:20 PM
