Leak
Old Mar 16, 2014 | 11:57 AM
turbogsr181's Avatar
Default Leak
Hello, I'm not the most savvy car guy, so I apologize in advance. I'm having trouble finding the leak..
http://tinypic.com/view.php?pic=ipz4wj&s=8#.UyYBiz9dUnE
I changed the Vtec solenoid gasket, and I thought for sure that was the problem.. The gasket itself was cracked.. However it still continues to leak down.. IDK if the oil is trapped in between the block and head or what.. Am I missing something else? where Could it be leaking from? It leaks down right over where the b18c is. I have wiped it off 4x after changing the gasket and the leak continues (though it is not nearly as bad).. Thoughts?
Old Mar 16, 2014 | 01:11 PM
B_Swapped93's Avatar
Default Re: Leak
distributor or the cam seal spay that whole area down with brake parts cleaner then you'll be able to pin point it.
Old Mar 16, 2014 | 03:20 PM
fcm's Avatar
fcm
Old Fart
Default Re: Leak
Ditto the above, clean the area, [I use engine degreaser] start engine and watch. 94
Old Mar 16, 2014 | 06:35 PM
Default Re: Leak
Thanks guys will do.
Old Mar 20, 2014 | 02:36 PM
Default Re: Leak
When you say Dizzy, did you mean the O-ring?
Old Mar 21, 2014 | 08:51 AM
DOHCvtecLOVER's Avatar
Default Re: Leak
Yeah that's what he meant. The O-rings dry out all the time on those distributors.
Old Mar 23, 2014 | 06:46 AM
Default Re: Leak
O-ring was hard as a rock and cracked. problem solved I think. Thanks guys.
Old Mar 23, 2014 | 02:10 PM
$MIKE$'s Avatar
Default Re: Leak
Not sure if someone said it but use some honda bond or RVt around the eadges of the cam deal for ex side
Old Mar 24, 2014 | 11:31 AM
Default Re: Leak
Is there a diff between hondabond and any other RVT? I did use some off brand RVT and applied it onto the cam seal. unfortunatly I didnt change it though, because they accidentally gave me the wrong ones. They gave me the one seals on the opposite side of the head.
Old Mar 24, 2014 | 11:47 PM
nicknack25's Avatar
Default Re: Leak
There is a difference, but either will work.
Old Apr 2, 2014 | 11:53 AM
Default Re: Leak
help me out with another problem guys..
https://honda-tech.com/forums/suspension-brakes-54/rotors-3201492/
hugodc2
Nov 1, 2015 08:10 PM
motegicivic
20
Sep 21, 2011 04:57 PM
rude_88
Aug 8, 2010 04:36 PM
jeremypr
Aug 2, 2009 05:05 PM
EGfosho
Sep 29, 2007 09:47 PM
