launch control!!
Old Mar 17, 2008 | 01:57 PM
ALIKZANBRO's Avatar
Default launch control!!
hello everyone, does anyone know what's a launch control and how can my b16 integra can have one? thanks!!!
Old Mar 17, 2008 | 03:38 PM
posHonda's Avatar
Im guessing you want a 2-step launch control. Its a feature on Hondata so you can go grab you one. I wouldnt suggest it if youre car is barely modded though.
Old Mar 17, 2008 | 08:24 PM
blowngsr1's Avatar
Default Re: launch control!! (ALIKZANBRO)
crome also has this, it holds a rpm while engaged then when you pop the clutch it allows you to run to full rpm then there is the no lift to shift it just keeps you from over reving while having it floored
Old Mar 17, 2008 | 09:02 PM
tweek_boii's Avatar
Default Re: launch control!! (blowngsr1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by posHonda &raquo;</TD></TR><TR><TD CLASS="quote">Im guessing you want a 2-step launch control. Its a feature on Hondata so you can go grab you one. I wouldnt suggest it if youre car is barely modded though.</TD></TR></TABLE>
like what do you mean BARELY modded
Old Mar 17, 2008 | 10:42 PM
jDMJeRk's Avatar
Default Re: (posHonda)
LOL... its beneficial even if the car is stock... what makes it bad?
Old Mar 17, 2008 | 11:25 PM
magicaltrout's Avatar
because a stock car is so weak you're better off getting some skill at driving/lauching. it's probably not bad for the car... just a waste of time and money. a car really is only as good as its driver (up to a point of course).
Old Mar 18, 2008 | 02:25 AM
ALIKZANBRO's Avatar
i got a built b16 engine with a lsd tranny 6 puck clutch i think it is strong. so the launch control is only for turbo cars&gt;?
Old Mar 18, 2008 | 02:27 AM
ALIKZANBRO's Avatar
blowngsr1 tell me more about the crome one please?
Old Mar 18, 2008 | 04:21 AM
blueDA9's Avatar
the launch control on turbo cars also has an added effect, when you are 2 stepping the turbo starts to spool. So essentially you leave the line at boost. Why do you want the 2 step anyway?
Old Mar 18, 2008 | 11:36 AM
ALIKZANBRO's Avatar
Default Re: launch control!! (blueDA9)
i don't know it sound like is a great feature, i also like the sound it produces. you know when you love cars, you wan everything for them
ALIKZANBRO's Avatar
by he way, thanks to everyone for the info.
Old Mar 20, 2008 | 10:34 PM
blowngsr1's Avatar
crome is a rom editor it allows you to change the "tune" on your car fuel and timing curve are adjusted, and rev limits,speed govners, and other things can be done to change the way the car runs also vtec can be changed to engage sooner or later depending on the power curve check out tunewithcrome.com also http://forum.pgmfi.org you will have to become a member at pgmfi to view or download some of the articles there is free version of crome and free data logging software at pgmfi you will have to do ALOT of reading but if you have questions feel free to ask, i have been tuning my acura and seriously destroying some new mustang gt's
Old Mar 20, 2008 | 10:46 PM
tweek_boii's Avatar
i never knew computers made cars faster.
Old Mar 21, 2008 | 11:25 AM
blowngsr1's Avatar
Default Re: launch control!! (tweek_boii)
the ecu in the car controls timing and fuel delivery, using the laptop for interface you can change the fuel and timing this is how the tuners do it, check out those sites it is a world of info and the keys to making faster hondas
Old Mar 21, 2008 | 11:58 AM
thewrai6th's Avatar
Just about all standalone tuning applications support launch control (CROME, UBER, HONBLAHBLAH, NEPTUNE).
The point is to launch at a specific, consistent RPM, if you are NA.
For boosted applications, it is for launching at a set RPM, but also, it is to spool the turbo before launch. In this case, you can hold the throttle wide open and your fuel and/or ignition cut will keep you from revving past the set point, as long as the car is stopped. This will spool the turbo much more than if you had just revved it to 5K and held it there.
In the case of the OP, just practice holding at the RPM you want to launch at. Free launch control
caspers_hatch
Jan 19, 2007 11:42 AM
oreo
Honda S2000
20
Feb 16, 2006 01:02 PM
headhunter
Jan 12, 2005 03:03 AM
Nextelbuddy
Apr 17, 2004 07:53 AM
JDMSiGuy17
Apr 15, 2004 06:03 PM
