koni yellow install help
Old May 14, 2002 | 12:59 PM
Integra187's Avatar
Default koni yellow install help
i just got my koni yellows installed at a shop and they said there is suppose to be two bolts on top instead of one (the bolts are around the the little rod right underneath adjustment tab). I was lookin at the koni instructions and it only showed one bolt. Can someone help me out and tell me if there is suppose to be two bolts or just one.
Old May 14, 2002 | 01:12 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: koni yellow install help (Integra187)
It should come with 2 thin jam nuts per shock. You install one, then install the other and tighten them together. My front shocks came with the wrong size jam nuts, so I had to get Koni to send me 4 new ones because I couldn't find anything similar in local hardware stores.
Old May 14, 2002 | 01:19 PM
Integra187's Avatar
Default Re: koni yellow install help (PatrickGSR94)
ya the guy said they gave me four smaller ones instead of the other kind. Did u contact koni for the bolts? and is it ok to drive like this. thanks for helping.
Old May 14, 2002 | 02:20 PM
GSRaCeRbOI's Avatar
in the little hardware baggie that Koni supplies.. there are supposed to be two small thin jamb nuts per shock.. you tighten one, then tighten the 2nd jamb nut onto the first so they make a tight connection and wont come loose... I'd call Koni and get them to send you out the jamb nuts.. I think their contact info can be found at http://www.koni-na.com (koni North America).. or just go to http://www.koni.com and click on contact info or whatever..
.I.Need.Money.
Suspension & Brakes
Feb 9, 2007 01:44 PM
rubens
Jul 18, 2003 09:11 PM
rubens
Jul 11, 2003 11:09 PM
Solo2Vtec
Apr 29, 2003 11:02 AM
ILUVTEC
Apr 15, 2002 11:41 AM
