KONI/Eibach question need help!!!
Old Nov 12, 2002 | 05:05 PM
Solipsist's Avatar
Default KONI/Eibach question need help!!!
I just put on my Koni sport yellows with the Eibach sport line springs & camber kit. It was to lower the car 1 3/4" to 2" all the way around, but the front end looks like it sitting up too high. I was told that this is tipical for Eibach. Is this true? Maybe the springs just need to settle. I'll take a photo but I can't get one to post.
Old Nov 12, 2002 | 05:07 PM
GSRaCeRbOI's Avatar
Default Re: KONI/Eibach question need help!!! (TEXASLS95)
I have the exact same setup as you (Eibach sportlines and Koni Yellows) mine is pretty low...
did you install the front spring perch correctly? on the fronts the spring perch faces DOWN.. on the rears the spring perch faces UP... yeah I know it sounds like a stupid question.. but I've seen people install them backwards and didn't know until they were told so...
my rear did sit a little bit lower.. but in no way was my front sitting high... I also have a pretty hefty audio system in the rear so maybe that contributes to it looking low but the fronts aren't high on my car...
Old Nov 12, 2002 | 05:08 PM
frogsr's Avatar
there was a post a few days ago about something similar. it had good pictures as well, but make sure the spring perches are in their upright position. this can essentially raise the front of the car if you have the perch sitting the wrong way up.
Old Nov 12, 2002 | 05:13 PM
Solipsist's Avatar
Default Re: KONI/Eibach question need help!!! (frogsr)
Great,
Thanks for the info. I'll check it out & post a photo in the morning. (if I can figure out how to do that) HINT HINT
Old Nov 12, 2002 | 05:24 PM
GSRaCeRbOI's Avatar
check out the pix of the spring perches in this thread
https://honda-tech.com/zerothread?id=322957
to post pix.. you upload your pic to your webspace..then you click reply.. then click on the icon that says "image" then in between the brackets and the IMG tags.. you enter the full webspace/addy of the pic... then click enter..
left set= front... right set/pair = rears... notice the spring perches....
pix courtesy of SilverB18C1
[Modified by GSRaCeRbOI, 6:31 PM 11/12/2002]
Old Nov 12, 2002 | 05:32 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: KONI/Eibach question need help!!! (GSRaCeRbOI)
front spring perches should look like this:
<BLOCKQUOTE>code:<HR><PRE>
________
_/________\_
</PRE><HR></BLOCKQUOTE>
NOT like this:
____________
\________/
[Modified by PatrickGSR94, 8:33 PM 11/12/2002]
[Modified by PatrickGSR94, 8:35 PM 11/12/2002]
Old Nov 12, 2002 | 05:35 PM
GSRaCeRbOI's Avatar
Default Re: KONI/Eibach question need help!!! (PatrickGSR94)
hahaha patrick
I tried doing that ansi graphic earlier but my spacing didn't come out..so I ended up deleting it and getting a pic from another thread...
Old Nov 12, 2002 | 05:46 PM
Community Builder
you have to use the *code* and */code* tags
Old Nov 12, 2002 | 09:39 PM
Solipsist's Avatar
Thanks for yuor help. I'll check it out in the morning & post photos from the shop.
Here's a test pic from ALMS @ Texas Motor Speedway back in 2001
[img]C:\My Documents\ALS2001\acura.jpg[/img]
kevinm1981
Suspension & Brakes
Apr 13, 2010 09:49 PM
Rayz_Si
Suspension & Brakes
Mar 28, 2007 07:10 PM
killaj12
Suspension & Brakes
Oct 3, 2005 05:56 AM
Cory man
Suspension & Brakes
Mar 8, 2005 01:13 PM
Brian_92GSR
Dec 15, 2001 01:30 PM
