knocking sound
What does a knocking engine sound like? Whichis bad? The knocking from crappy gas or knocking that tells you a rebuild is needed. How to tell...
Can you tell I am in need of knowledge?
I want to know if I just need an adjustment or a rebuild.
i know sumtimes if ur low on oil ull get a knocking now if ur low and u add oil and the knocking goes away ur fine HOWEVER if u add oil and it still knocks then plan on spending sum money
rod knock sounds like someone under the car hitting the back of the block with a hammer, but faster. bad fuel or timing knock sounds more like a light pinging noise when the engine is reved up or under a load. both are bad but the ladder of the two can be fixed alot cheaper.
Honda3133
37
Sep 1, 2011 02:08 AM
Drew96EJ
Jul 25, 2004 03:25 PM
a1320honda
Jun 17, 2004 03:58 PM
MrEG6er21
14
Mar 24, 2004 10:33 PM
