knock sensor problem
Old Apr 18, 2009 | 05:39 AM
stantheman01's Avatar
New User
Default knock sensor problem
Hey guys I need some input..I have a 99 teg gsr with b18c5 the cel keeps popping a o2 sensor bank 1 and knock sensor bank1 and last but not least a catylist eff below manufacture spec code. The o2 sensor was wired wrong fixed that...put new p72 obd2 ecu in place to elimnate a ecu malfunction. Changed the knock sensor but the code still comes up and now a code comes up for tps sensor low voltage. I bought this teg with the engine swap already done and I belive that some of this wireing is wrong. When you drive it it cuts out when cold but when it warms up its better. I know vtec is disabled as long as a knock sensor code is on. Any input on this will get you a hundred virgins in heaven...Thanks
brcivic411
17
Aug 26, 2011 01:15 PM
SpoonFedEj8
Dec 23, 2008 03:11 PM
davken1102
Feb 6, 2004 10:42 AM
Fardoche
Jul 31, 2003 10:29 PM
