Kill switch on the Integ.... quick question
Old Sep 11, 2004 | 07:59 PM
GuitarSlinger78's Avatar
Default Kill switch on the Integ.... quick question
Ok so I think I've read enough to know that its the yellow and green wire. I am going to set this up tomorrow but wanted to make sure I had this all down.. minus the diagrams and numbers and all that...is this basically what to do?
1. Get a switch. Have a power and load wires, use thicker gauge wire the further from the actual splice.
2. Crimp the power wire to the yellow/green that goes to the front. Crimp the Load into the wire running into the pump
2. Basically your done.. try it and hope you dont blow any fuses.
What Im a lil confused about it after reading all these posts why do some say up the fuse to a 25 if its a 15? Is this a necesarry step? Thanks for any info.. seems like a rad idea.
Old Sep 11, 2004 | 08:37 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Kill switch on the Integ.... quick question (JoE94Integ)
crimp solder
make sure your switch is at least 25 amps
thecruzs2007@yahoo.com
Jan 2, 2010 07:11 PM
standbackimapro
Audio / Security / Video
Feb 21, 2007 07:38 AM
GuitarSlinger78
Sep 12, 2004 08:16 AM
Simple
13
Jan 10, 2004 07:57 AM
Remmy
Feb 3, 2003 06:55 AM
