JRSC reliability
Old Sep 26, 2002 | 08:13 PM
gsrpilot8000's Avatar
Default JRSC reliability
I have a 99 gsr. I am thinking of getting a JRSC sometime in the future and I was concerned about its reliability (since my gsr is my daily driver). If I was to get the kit and leave it a 6 psi, would you say it is fairly reliable for daily use? Thanks for the replies.
Old Sep 26, 2002 | 08:18 PM
bocian's Avatar
Default Re: JRSC reliability (gsrpilot8000)
this topic has been covered a couple times. to what i have read a jrsc is more reliable then turbo. how reliable depends mostly on the maintenance of your car. if you keep your car happy then you shouldnt have any problems with the jrsc, but one terribly wrong move and boooom.... blown engine. but yea the jrsc is pretty reliable in comparison with any other fi setup but its all about the overall care of your car... hth
Old Sep 27, 2002 | 01:57 AM
AccrdATK's Avatar
New User
Default Re: JRSC reliability (bocian)
umm.. i have a friend with a jrsc in his prelude.. and he changes his oil every 2500.. and it has been running fine for close to a year... its very reliable...he drives it daily as well.. just make sure you maintaince the car when its time.. or you'll be in a world of pain down the line
Old Sep 27, 2002 | 04:15 AM
GSR901's Avatar
Default Re: JRSC reliability (JdMR-536)
it is very reliable.
Old Sep 27, 2002 | 05:40 AM
metal-x's Avatar
Default Re: JRSC reliability (B18Cwon)
no problems so far
maintain properly and you'll be fine
Old Sep 27, 2002 | 06:19 AM
GAperformance's Avatar
New User
Default Re: JRSC reliability (metal-x)
Put it in, get it tuned correctly and you don't have to worry about it. You have to change the shorter belt every 10k miles, but that only takes 20 minutes. My only complaint is I ate through my tires in a month. Peeling is fun for a while...
Old Sep 27, 2002 | 06:55 AM
slowEJ6's Avatar
Default Re: JRSC reliability (bkw97lude)
id say the jrsc is reliable at 6psi.....but i hear some horror stories about trying to go with a higher boost pulley...sooome real horror stories.
Old Sep 27, 2002 | 07:13 AM
TGUNNER's Avatar
i have installed alot of jrsc's.i also put one in my 2001 gs i am pushing 10 psi with no problems all day every day!!!! they are very reliable as long as there tuned right and you service your car regularly!!!
Old Sep 27, 2002 | 08:54 AM
passinUby's Avatar
Default Re: JRSC reliability (TGUNNER)
got one in my teggy. 8lbs. of boost just by stepping on the pedal ain't bad. with any major mod, just remember to do regular maintenance and keep an eye out on those belts
andreiscv
May 17, 2004 01:59 PM
