jerking while accelerating 95 gsr
Old Mar 19, 2008 | 06:41 PM
llozll's Avatar
Default jerking while accelerating 95 gsr
hey guys,
having problem with my 95 gsr.
it started like couple month ago, the car jerked in 4k rpm(in 2nd and 3rd gear) and seemed it doesn't accelerate properly(felt less pwr too). now, it jerks when take off, and every gear jerks like when i was driving stick shift for the first time. there's no constant increase of acceleration. sometimes, the car takes off and i step on the gas pedal to accelerate, i get no response, and i try to rev couple time then it picks it up and go but still jerks in every gear.
i tried fuel part partially by changing fuel filter and injector cleaner, but don't seem it's helping. im about to check iacv.
is there anything else might cause this problem?
any inputs will be appreciated.
thanks,
-oj
Old Mar 19, 2008 | 06:54 PM
llozll's Avatar
Default Re: jerking while accelerating 95 gsr (llozll)
no one yet?
c'mon help outz!!
Old Mar 19, 2008 | 06:55 PM
crazyguy's Avatar
are all the injectors working fine ? car idels normal?
Old Mar 19, 2008 | 07:16 PM
Sumslapper's Avatar
Year 3030
Default Re: jerking while accelerating 95 gsr (crazyguy)
My car used to randomely jerk and then it just turned off. It was the distributor.
Old Mar 19, 2008 | 07:19 PM
goota's Avatar
run some injector cleaner.
Old Mar 19, 2008 | 07:28 PM
llozll's Avatar
Default Re: (goota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goota &raquo;</TD></TR><TR><TD CLASS="quote">run some injector cleaner.</TD></TR></TABLE>
yea im trying the first bottle now. ran about 10mi but it's still same.
idle is lil low around 6-700 or 800 around there.
Old Mar 19, 2008 | 10:42 PM
D@9 A.D.B.'s Avatar
Default Re: (llozll)
how are your plugs and wires....my db used to act like that when i shift or start from a complete stop it would jerk...change my plugs, wires, cap and rotor and it was fine
Old Mar 19, 2008 | 10:44 PM
b20integrapower's Avatar
Default Re: (D@9 A.D.B.)
check the distributor.
Either it is loose and is moving back and forth, or the cap and rotor are going out. 99% sure that is your problem.
Old Mar 27, 2008 | 07:27 AM
llozll's Avatar
Default Re: (b20integrapower)
yea it was the rotor
old rotor was all messed up.
changed to new one and runs like before! jyea!
thanks guys!
EricsGSR
Apr 25, 2012 07:59 PM
TruGsr1
Nov 14, 2006 03:35 PM
Promina
Jan 23, 2006 05:00 PM
blacK_Dc4
Sep 8, 2005 01:32 AM
