jdm conversion problem
Old Apr 14, 2007 | 10:14 AM
hmongyaj87's Avatar
Default jdm conversion problem
i have a 94 integra gsr and i'm going to put on hid headlights for my conversion.. just got a question. will my abs be in the way for the hid headlights and if so, can i use the 98 up integra's abs to replace mine?
Old Apr 14, 2007 | 12:33 PM
Pee Wee's Avatar
Default Re: jdm conversion problem (hmongyaj87)
this has been discussed a few IIRC. search and you shall find your answers. I just can't remember
Old Apr 14, 2007 | 12:39 PM
Tornadom's Avatar
The 98+ abs unit will clear the HID ballasts, the 94-97 will not.
Old Apr 15, 2007 | 07:16 PM
TemjinX2's Avatar
just relocate the ballast. Its easier just to relocate it then to install a entire abs unit.
Old Apr 15, 2007 | 07:20 PM
pvt_awol's Avatar
Default Re: (TemjinX2)
that is REALLY hard to do on the stock HID headlights. i.e. --> impossible. The ballasts on the stock headlights are part of the housing. You can't simply just put it somewhere else, like you can with an aftermarket kit.
Old Apr 15, 2007 | 09:49 PM
skUnK2jdm's Avatar
Default Re: (pvt_awol)
get the 98 abs
Old Apr 16, 2007 | 08:05 AM
Journeytype-r's Avatar
Default Re: (skUnK2jdm)
yes you'll have to change the ABS its alot easier than the other way of moving the ballast around
Old Apr 16, 2007 | 08:16 AM
bseries_ben's Avatar
Default Re: (journeytyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TemjinX2 &raquo;</TD></TR><TR><TD CLASS="quote">just relocate the ballast. Its easier just to relocate it then to install a entire abs unit. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by journeytyper &raquo;</TD></TR><TR><TD CLASS="quote">yes you'll have to change the ABS its alot easier than the other way of moving the ballast around</TD></TR></TABLE>
lol... somebody's lyyyyyyyyyyyingggg
TypeSiR-G
May 6, 2011 11:45 PM
maxboost_50psi
Aug 19, 2006 10:05 AM
SiRTifiedacc
Dec 15, 2005 12:14 AM
Joe Psycco
Jul 20, 2004 03:35 AM
jdmvtec28
Jun 27, 2004 02:26 PM
