ITR cat
Old Jan 1, 2003 | 07:46 PM
DARKsideLS's Avatar
Default ITR cat
I would assume that a type r cat would flow better than an stack ls one,
woud i see any gains by getting one, is it worth the trouble.
Old Jan 1, 2003 | 08:36 PM
Padawan's Avatar
Darth ModerVader
Default Re: ITR cat (DARKsideLS)
If you want to replace the cat., go with a high-flow aftermarket replacement. Although the ITR cat. does flow slighty better, it wouldn't be worth the time, effort and expense to swap it.
Old Jan 1, 2003 | 10:53 PM
Brasspremier's Avatar
Default Re: ITR cat (Padawan)
i'm only considering getting one cause i wanna get the ITR header as well
Old Jan 2, 2003 | 09:48 AM
Padawan's Avatar
Darth ModerVader
Default Re: ITR cat (Brasspremier)
Are you referring to the USDM ITR exhaust manifold? What car would you be installing this on?
Old Jan 2, 2003 | 10:30 AM
PM-Performance's Avatar
your wasting your time and money if you get an itr cat and usdm header, but if you want to spend it , ill sell it to you,
ill tell you now they are almost exactly the same becuase i still have the parts from my 99GS and extra parts from my 01 R and the **** isnt worth getting for the miniscule diff .
the cat looks the same , the header downpipe is the only reall diff, but you wont see any more power from it
what IM asying is dont get cuaght up in the Type R thing , its over rated.
sohctodohc
May 15, 2007 08:43 AM
BRAiN8
Feb 2, 2005 08:34 AM
ITR #1202
Oct 24, 2001 01:07 AM
