itb
Old Oct 15, 2004 | 10:20 AM
acintegragsr's Avatar
Default itb
how much power could u make off of this and what is the benifit of having one of these thing on your engine
Old Oct 15, 2004 | 12:45 PM
in case u dont know im talking about an individual throttle body
Old Oct 15, 2004 | 12:51 PM
Padawan's Avatar
Darth ModerVader
Default Re: itb (acintegragsr)
Well, they're individual throttle bodies (as in four of them), and to be completely honest and with no intention whatsoever of sounding rude, if you're asking this question then ITB's most likely aren't the best idea for you.
Old Oct 15, 2004 | 12:54 PM
MR-MUGEN's Avatar
Default Re: itb (Padawan)
itb's are only good if you have a motor that is really built , like 330whp built if you are a small time power motor you will lose power instead of getting power out of it , cost for a good set is about $2200 , for a cheap set mad out of motorcycle carbs. about $600( no good )
Old Oct 15, 2004 | 02:35 PM
GS-Rdriven's Avatar
Default Re: itb (jdm92daintegra)
i've always wondered since there is no intake....where does the air get filtered?
Old Oct 15, 2004 | 02:36 PM
PLAGUED_DB7's Avatar
Default Re: itb (GS-Rdriven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GS-Rdriven &raquo;</TD></TR><TR><TD CLASS="quote">i've always wondered since there is no intake....where does the air get filtered?</TD></TR></TABLE>
there is lil mushroom like filters that are inside each body
or I have even seen marshmellow type filters as well
Old Oct 15, 2004 | 02:38 PM
rgbpmp's Avatar
Usually it doesnt get filtered. But you can fab up one with filters, or use a mesh screen to filter the air.
Old Oct 15, 2004 | 03:00 PM
A L I A S's Avatar
Default Re: itb (rgbpmp)
or one of these
the big cf cone type thing has a filter in it, and it obvously doubles as a type of ram air induction
Old Oct 15, 2004 | 03:43 PM
user 996328629's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm92daintegra &raquo;</TD></TR><TR><TD CLASS="quote">itb's are only good if you have a motor that is really built , like 330whp built if you are a small time power motor you will lose power instead of getting power out of it , cost for a good set is about $2200 , for a cheap set mad out of motorcycle carbs. about $600( no good ) </TD></TR></TABLE>
Wow your a ******* moron..
Back to your question, SEARCH.
Old Oct 16, 2004 | 12:40 AM
MR-MUGEN's Avatar
Default Re: itb (Swags04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swags04 &raquo;</TD></TR><TR><TD CLASS="quote">
Back to your question, SEARCH. </TD></TR></TABLE>
hey man uncalled for , if im wrong just say it but don't call me a "******* moron"
Old Oct 16, 2004 | 02:00 AM
GrayT's Avatar
hey man uncalled for , if im wrong just say it but don't call me a "******* moron"</TD></TR></TABLE>
Well said.
Old Oct 16, 2004 | 02:03 AM
Id call myself a moron also, if i went around and posted completly misleading answers to peoples' questions
Old Oct 16, 2004 | 03:13 AM
Smeeg Heed's Avatar
Independant throttle bodies would give you a decent boost of power on an all motor engine that needs it. Having the independant throttle bodies evens out the airflow to the cylinders and reduces turbulence. It's expensive, but generally going all motor is a lot more expensive than FI.
Ignore the guy that said something about 330whp. There is noone on this planet get makes 330whp out of a B18C.
If you were planning to go hardcore all-motor, ITBs are for you. But you'd want to sort out other things first - header/exhaust system, valvetrain, higher compression, ECU tuning. I would also say an intake and manifold, but if you're going to put ITBs on then you wouldn't need those.
Old Oct 16, 2004 | 06:22 AM
jdmotorsports's Avatar
Default Re: itb (Smeeg Heed)
look up user tbone. he has the itb's on his 2.0l rex. he's currently tuning them to work right, but he has somewhere in the 250hp range. and he was running 11's before the itb's.
Modified by jdmotorsports at 11:35 AM 10/16/2004
Old Oct 16, 2004 | 07:14 AM
im not getting them right now ive just been seeing them alot lately and and at first didnt know what the hell they were but then i found out and wanted to know what kind of power it was giving because of the lack of an intake
Old Oct 16, 2004 | 07:16 AM
is that any old kind of b-16 or b-18 or is it that new high powered honda motor ive been hearing about
Old Oct 16, 2004 | 01:05 PM
GrayT's Avatar
Default Re: (acintegragsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acintegragsr &raquo;</TD></TR><TR><TD CLASS="quote">is that any old kind of b-16 or b-18 or is it that new high powered honda motor ive been hearing about</TD></TR></TABLE>
Wha....?
Old Oct 16, 2004 | 01:20 PM
92TypeR's Avatar
FSAE
ITB's are great for response. Which is primarily why people use them. Power is difficult to attain using mild compression unless you tune them out really well.
A lot of people are making their own DIY ITB's, there have been a couple really good posts in the all-motor forum regarding them, so do a little searching and you can see how people are making them from motorcycle throttle bodies.
Right now the best system on the market is the Jenvy throttlebodies, mainly because they offer the widest range of sizing, so you aren't stuck with too small or too large throttlebodies. http://www.jenvey.com/
juanchoenuncrx
Feb 17, 2008 03:57 PM
aholeb18
Jul 29, 2007 05:48 AM
saintspall
15
Jan 23, 2007 02:45 AM
themex77
Sep 25, 2004 04:23 AM
dominate9
Feb 4, 2004 09:32 PM
