Interior Swap gone wrong, HELP
Old Mar 27, 2008 | 10:34 AM
bobmugen's Avatar
Default Interior Swap gone wrong, HELP
I purchased a full black interior for my 94 integra. i am about 50% done with the swap i just have the carpet and 2 seats. i didnt finish swapping out the dash because i couldnt get the old steering wheel out, the srs plug or whatever was still plugged in and i dont know how to take it out. so basically i drove it yesterday with 2 seats and a loose dash, first my sub was working fine, then it goes out, i check all the plugs and the amp fuse it seems to be good. later my kenwood deck goes onto protect mode so i think its probable the radio wires.
Then at first my corner lights and tailights were working but when i turned them on again only my hid headlights work, my cluster and center console lights didnt turn on either
Does anyone know whats wrong? and how to remove the steering wheel?
Old Mar 27, 2008 | 11:24 AM
T3@MD3FC*N's Avatar
check your fuse's....
Old Mar 27, 2008 | 12:18 PM
steveteggy92's Avatar
Default Re: (T3@MD3FC*N)
http://www.hondahookup.com - go to the "manuals" on the left and download the PDF manual for a 94 integra.
You'll need an account.
Old Mar 27, 2008 | 08:34 PM
bobmugen's Avatar
anyone else have any advice?
Old Mar 27, 2008 | 09:25 PM
DA9_DAD's Avatar
Default Re: (bobmugen)
just do some general searching on the net.
http://hondaswap.com/general-t...34523/
it looks like you'll need an acct in order to see the pics. but if you read everything step by step..you won't need pics.
Found one for the dash...I know you've already done that.
https://honda-tech.com/zerothread?id=954173
Modified by DA9_DAD at 10:32 PM 3/27/2008
Old Mar 27, 2008 | 09:26 PM
BlueIntegraBoy's Avatar
To remove steering wheel, unplug negative terminal of battery for at least 20 minutes. Remove the side plastic panels of the steering wheel. Unplug the yellow SRS plug by sliding back one end of the plug and then pull the plugs apart. Take a T30 torx bit (a flathead will also work) and remove two two Torx screws on the side of the airbag. Take a 19mm socket and loosen the middle bolt. Take two hands and put them on opposite ends of the wheel and give it a few quick, hard jerks to pop the wheel off the spindle.
Old Mar 27, 2008 | 09:38 PM
DA9_DAD's Avatar
Default Re: (BlueIntegraBoy)
<FONT SIZE="3">I FOUND IT!!! & IT WAS IN H-T, TOO</FONT>
https://honda-tech.com/zerothread/1875083
Pics and everything. Good luck
mac_24_seven
Mar 13, 2012 03:34 AM
tyler100
20
Aug 2, 2008 11:25 PM
TealCivic93
Apr 16, 2005 04:21 PM
2LoW4FaThOeS
Dec 11, 2002 11:32 AM
InfamousRS
Mar 5, 2002 04:02 PM
