interior lighting question
Old Dec 17, 2004 | 08:16 PM
TeaAddict's Avatar
Default interior lighting question
i need to replace the bulb on my interior lighting. (gen 3)
its not the dome light, but the light towards the front of the car. the one with two buttons @ top, right infront of the sunroof.
do i just jam a flathead in there and it pops off? i don't want to wreck anything.
thanks
Old Dec 17, 2004 | 09:36 PM
LSvtec03's Avatar
Default Re: interior lighting question (TeaAddict)
yes. use as small a screwdriver as you have.
Old Dec 17, 2004 | 11:17 PM
confucius's Avatar
Default Re: interior lighting question (LSvtec03)
and dont forget, ur not a real import tuner, if you dont use blue blubs and neons.
Old Dec 18, 2004 | 01:08 AM
TeaAddict's Avatar
where exactly do i put the flathead, between the plastic and the rim, or the rim and the outside.
its 2 am so i'm not gonna post pics.
Old Dec 18, 2004 | 01:15 AM
db8sedan's Avatar
if you look carefully you'll see the notches where the cover is being held in place, use a small flathead and insert in that area to remove it...
Old Dec 18, 2004 | 09:59 PM
calxtreme's Avatar
yup, pops right out when you pry the slots
Old Dec 18, 2004 | 10:55 PM
vidanator's Avatar
Default Re: interior lighting question (confucius)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confucius &raquo;</TD></TR><TR><TD CLASS="quote">and dont forget, ur not a real import tuner, if you dont use blue blubs and neons.</TD></TR></TABLE>
haha
yeah there should be tabs and they should just pop out
Old Dec 18, 2004 | 11:11 PM
Monkey Z.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confucius &raquo;</TD></TR><TR><TD CLASS="quote">and dont forget, ur not a real import tuner, if you dont use blue blubs and neons.</TD></TR></TABLE> EH EH! PULSE NEON not regular otherwise your visual points wont go up enough to get on a mag Yo!
Old Dec 18, 2004 | 11:16 PM
RidinStock's Avatar
Default Re: interior lighting question (DarkblueInteg)
I read in another thread that if you can fit it, use a towel or something to cover the screwdriver so it doesn't scratch/hurt anything. I don't know if that spot is too small though...
Old Dec 19, 2004 | 12:44 AM
calxtreme's Avatar
Try using a paper towel....you're over analyzing all of this. That piece is meant to be taken apart for bulb replacement.
Hey, I wouldn't mind swapping the stock bulb for some nice white LED ones though.
k0rupt_ed
Detailing
May 14, 2011 05:19 PM
ap1$2k
Honda S2000
Sep 11, 2006 01:16 PM
sergio
May 2, 2006 01:32 PM
93_teg_CT
Feb 15, 2006 03:28 PM
Jonathan_ED3
Audio / Security / Video
Jan 5, 2005 04:58 PM
