Interiment wiper problem.
Old Jun 24, 2009 | 11:07 PM
4DRmafia's Avatar
Default Interiment wiper problem.
I looked and looked for info for Interment wiper not working and couldn't find any. I just got my Da yesterday and only thing wrong is the Interment part does not work. Low and High works just fine and rear wiper works great as well. Could this be switch problem or something else like wiper modular on the fuse box?
Old Jun 25, 2009 | 09:06 AM
4DRmafia's Avatar
Default Re: Interiment wiper problem.
Aww man, help me lol
Old Jun 25, 2009 | 09:21 AM
koss1229's Avatar
Might be the switch itself. I made an implant to a civic switch to make a rear wiper work in my Teg, so I had to brake it apart. There is a little plastic thing that switches from one position to another. Something might be wrong with it being broken or not aligned properly. You can tell if when you put it in Interment mode and it works Slow, and then Fast in Slow mode - the positioning is wrong.
Sorry for my Eng and I'm not that of a professional, but this is what I think. Hope it will help
Old Jun 25, 2009 | 09:30 AM
xxfile's Avatar
If not the switch, it might be the ICU. Please read the following post
http://www.g2ic.com/forums/showthrea...=ICU+capacitor
Old Jun 26, 2009 | 05:14 AM
4DRmafia's Avatar
This is weird. I swapped a known good wiper switch on this morning. I had a spare one laying around and it was from a ef civic hatchh, so I unscrewed the wiper unit off from the civic base and screw it on the integra base. Wire plugs right into it, I thought it be okay, until I turn on the car and hit the int position, it acts like it's on low, then I move it over to low, same thing, then I put it on high, it speeds up. I was wondering if the civic and integra wiper internals are different? Or are they both wired different?
Old Jun 26, 2009 | 05:18 AM
VTEC_PRODUCTION's Avatar
get a replacement made for YOUR car. im 90% sure this is the solution.
Old Jun 26, 2009 | 05:28 AM
4DRmafia's Avatar
I figured to see if it worked or not, it worked but acts like LOW position. lol. I'll get a new switch and ICU just in case.
Old Jun 26, 2009 | 08:29 AM
koss1229's Avatar
They are same for civic and integra, except there is no rear wipers on civics.
You need to position it right when you swap it. Play with it, mine acted the same at the first time.
Old Jun 26, 2009 | 08:56 AM
stocker2shocker91's Avatar
I requested a short story for a title.
ya i was going to say it might be the icu, i had this problem when i bought mine
also check to see if the rear defrost works it is also in the icu, if that is acting up as well thats your problem
Old Jun 26, 2009 | 10:24 PM
4DRmafia's Avatar
yeah, my rear def orange light dont come on. Is that the ICU related?
Old Jun 27, 2009 | 08:56 AM
jhammond_82's Avatar
Reject Papi
4drmafia... are you driving my car? lol. i have the same exact issues with mine. my intermitant works, well, intermittingly. some times it works, then its slow like slow speed, next time, it won't work at all. my rear defroster works, but then it doesn't. if i hold the button in, the light stays on, sometimes. its retarded. i'm definately gonna check out the icu theory.
Old Jun 27, 2009 | 11:52 AM
4DRmafia's Avatar
I went and got a ICU today at the junkyard and I'm getting ready to put it on soon though.
Old Jun 28, 2009 | 08:44 AM
4DRmafia's Avatar
I poped in my somewhat new ICU I got from the junkyard and still no dice and my rear def still not coming on. I prolly got another bad ICU.
Old Jul 7, 2009 | 12:14 AM
4DRmafia's Avatar
Update: I haven't update it in a while. The theory is now solved, it was an ICU. I'm on my 3rd one and hoping it be my last one. Pop that 3rd ICU in and it works and rear def works too.
Old Jul 7, 2009 | 06:12 AM
nsxtasy's Avatar
H-T Order of Merit
Do you mean...
interment
Main Entry: in·ter·ment
Pronunciation: \in-ˈtər-mənt\
Function: noun
Date: 14th century
: the act or ceremony of interring, i.e. depositing (a dead body) in the earth or in a tomb
...or do you mean...
intermittent
Main Entry: in·ter·mit·tent
Pronunciation: \-ˈmi-tənt\
Function: adjective
Etymology: Latin intermittent-, intermittens, present participle of intermittere
Date: 1601
: coming and going at intervals : not continuous <intermittent rain>; also : occasional <intermittent trips abroad>
FRKWOO
Aug 6, 2009 11:44 AM
teg969
Dec 18, 2006 12:37 PM
asianalbutt
Sep 15, 2005 06:24 PM
rexdriver88
Aug 28, 2004 10:34 PM
metal-x
Nov 17, 2003 12:59 PM
