integra wont start. HELP!
Old Sep 14, 2011 | 05:19 PM
importracegirl's Avatar
Default integra wont start. HELP!
-it starts ONLY by push start... NO jumper cables.
-no clicking, no cranking, no noises.
-everything (lights, radio, fuel pump, etc) turns on BUT motor.
-had battery tested & recharged.
-had starter tested.
STILL NOTHING.
what else could it be? please help. im a girl and i work on my own car via google, youtube, & honda-tech & i refuse to bring it somewhere. could it be the main relay? the battery terminals, the solenoid on the starter?
any help would b great THANKS
p.s. i am limited in tools as i dont have a volt meter..
Old Sep 14, 2011 | 05:30 PM
Default Re: integra wont start. HELP!
any1????
Old Sep 14, 2011 | 07:26 PM
bonstokLS's Avatar
I am taking this "push button" starting method is custom fab'd.
Can you verify the install is clean?( Need a DMM at least to check continuity)
Do you have some sort of kill switch on this car?
I always check the following: Fuel, Spark and Air... Make sure the basics are present.
Old Sep 14, 2011 | 07:40 PM
DumpdEJ6's Avatar
I like the tuna here
I think she means push start as in "have to push the car, then pop the clutch" method of starting.
Old Sep 14, 2011 | 07:46 PM
cdaiscool's Avatar
Check continuity of wires between starter and battery.
Old Sep 14, 2011 | 08:35 PM
NemesisCBR's Avatar
if it were anything regarding fuel, spark, air, wouldnt it have trouble staying on or starting with a push method? Theres a good chance it could be connectings near the ignition. Take the steering column plastic off and start inspecting. Dont know if you checked the ground wire to the starter but i would make sure those wires are good.
There was another thread recently where FCM posted instructions on a few things to check. Ill see if i can find it real quick.
Old Sep 14, 2011 | 08:48 PM
NemesisCBR's Avatar
heres the link, good info from fcm and couple others in there
https://honda-tech.com/forums/acura-integra-6/car-will-not-crank-constant-beep-noise-when-trying-start-2957607/
Old Sep 14, 2011 | 09:04 PM
LordAphotic's Avatar
check grounds. did u unplug any of your ground cables? the one that goes over the valve cover is pretty important and without it usually the car will have the symptoms your talking about.
Old Sep 14, 2011 | 10:01 PM
bonstokLS's Avatar
my bad... I read that the WRONG way. LOL..
Please let us know if you try any of the suggestions...except mine. LOL
Old Sep 14, 2011 | 10:14 PM
FD2Argi's Avatar
most likely your starter is starting to go bad.
Old Sep 15, 2011 | 10:58 AM
Teggers's Avatar
Sounds like the starter solenoid. The plunger gets stuck from corrosion and fails to make contact. It's apparently a common problem with these cars that comes with age. It isn't very hard to remove and rebuild with a kit. I did mine using a kit I found on Ebay.
In the mean time, you could try loosening the solenoid by repeatedly turning the key on and off, and holding it while in start position. That sometimes helped mine. (Not liable for unintended damage this may cause the electrical system, lol).
Could also be the fuel main relay, but I thought so with mine, and it wasn't the problem.
Old Sep 16, 2011 | 12:52 PM
Lord Helmet's Avatar
whenever you're push starting the car to have it run, you're bypassing the starting. If nothing else is wrong then I am quite sure 100% it's your starter. F&*K rebulding the starter solenoid, it's cheaper to just get another starter.
Old Sep 16, 2011 | 03:11 PM
fcm's Avatar
fcm
Old Fart
Importracegirl, try a bypass jump... https://honda-tech.com/forums/showth...&highlight=fcm
Feel free to IM me if you have questions. 94
Old Sep 16, 2011 | 06:29 PM
turboskratch's Avatar
Have you tried getting a big wrench or rod of some sort and banging the starter?
speedfreek128
Honda S2000
Mar 13, 2015 07:49 AM
Jlove1993
Feb 3, 2015 09:43 AM
Eg Fool
Jun 7, 2011 07:54 PM
g5r
Oct 5, 2007 10:07 AM
cbstudd77
Dec 20, 2006 07:40 PM
