Integra Torque Specs or Sequence
Okay, I just did a head job on my integra LS and I cant seem to find the torque specs or sequence for my head. Is there is anybody out there who knows the torques specs and sequence for the headbolts and cams.....
start in the middle and work your way out first at 28 lbs/ft and then at 63lbs/ft
10 3 1 5 7
8 6 2 4 9 It might not be the same as the factory manual but close enough
For the cam covers 20 lbs/ft start in the middle and work your way out, get them all hand tight to make sure the dowel pins are aligned before youu rank them down
10 3 1 5 7
