integra speakers
Old Mar 17, 2005 | 05:14 PM
desiromeo812's Avatar
Default integra speakers
hello guys just bought a 98 integra gsr and wanted to replace all of my speakers im thinkin about running rockford speakers 75wt rms with 150 max. from a kenwood 720 watt amp 65x4. is there any possible way i would be able to fit 6x9 in the back where there are 6.5 inch speakers if yes does anybody kno how i want it too fit inside the stock grill ... help needed asap
Old Mar 17, 2005 | 05:28 PM
acuracy r's Avatar
Default Re: integra speakers (desiromeo812)
eh, never heard of someone puttin them in the stock rear location. i think your best bet would be the hatch cover...
Old Mar 17, 2005 | 06:24 PM
GsrGilbert's Avatar
Default Re: integra speakers (acuracy r)
its very possible but requires a tad bit of modifacation. from my experience id just stick with the stock size and "match" your system to a subwoofer.
Old Mar 18, 2005 | 10:53 AM
Default Re: integra speakers (GsrGilbert)
how about 6x9 in the front cuz since i am puttin a whole system i want the best bang for the money. thas y i wanna go with *** much bass and power hanling i can which 6x9 privides
Old Mar 18, 2005 | 11:31 AM
Honda Hick's Avatar
No way you're going to fit 6x9s in the front. You may in the back locations but it's going to require you to pull out the whole side plastic parts that go from the doors back to the rear. Then you'd have to make some custom pieces to mount the speakers too. It probably wouldn't sound any better than the 6.5s because the holes aren't that big in the sides.
Believe me, you're going to have a hard enough time fitting aftermarket 6.5s in there to begin with. I needed to make spacers for all 4 because the stock plastic baskets weren't deep enough and the actual holes were too small in diameter. In the rear I had to pull those 2 side plastic pieces (major PITA) because I couldn't physically fit the 6.5s in the hole with the grill on it. If I had to do it again I would have just gotten 5.25's at least for the back.
Old Mar 18, 2005 | 04:17 PM
calxtreme's Avatar
I think 6x9 in the back wouldn't be hard since there's plenty of room in that panel. You just have to screw on some custom brackets. The front might work if you cut the metal circle into a big oval, but you might have a problem with the sides of the front speaker touching the plastic cosmetic panel. It's on you, but I would stick with 6.5 but do it component style.
Old Mar 18, 2005 | 09:15 PM
ekzrated's Avatar
Go with Infinity Speakers. Clean, loud, beautiful. You can fit 61/2" in front, with minor mods, but the back, you may be looking at more work... Just my $0.02 -ekzrated
Old Mar 18, 2005 | 10:09 PM
Bay_707's Avatar
if you have a 4 door gsr you can fit 6x9's in the back. There is a hole for 6x9's in the back of coupes but funny enough you cant fit one back there... aftermarkets do have a hard enough time fitting in the back, and you usually have to take off the grille because the tweet comes out too far
Old Mar 19, 2005 | 10:36 PM
Default Re: (Bay_707)
up
excel88
Jul 18, 2004 10:56 AM
ieatrice
Audio / Security / Video
Feb 22, 2004 05:07 PM
streakz
Dec 1, 2002 05:43 PM
SmokeU
Sep 18, 2002 01:47 PM
