Integra GSR Problems!
First of all heres my mods that i have due to people telling me its the mods and the ecu cant opperate correct:
Fidanza Flywheel
Energy Suspension mount inserts
Crower Stage 2 cams
Megan Racing Hi-Flo converter
Bosch Universal Oxygen Sensors-One Before and One After
Stock Header-Till turbo goes on
2.5" cat-back Exhaust
Walboro 255 fuel pump
standard injectors-till turbo goes on
standard ecu
and
Adj FPR set a stock setting
First Problem:
my car drives fine but when i come to a stop and push the clutch in ONE the rpms drop really low and goes back to normal idle rpm TWO it completely DIES and i have to start it again THREE the idle rpm goes from normal to really low to 1k rpm and does it repeatedly till you start going again and FOUR same as 3 but....if i let off the brake pedal it idles fine. when i stop it will do one of these 4 things. What would be the cause of this?
Second Problem
when i step down on the throttle and let it go to VTEC it: ONE it does not go in at all TWO the rpms dont go up as fast as they shoud THREE feel like only half the engine is engaged into VTEC. What would cause this stupid problem?
Any suggestions please help me out
Thanks
Fidanza Flywheel
Crower Stage 2 cams
standard ecu
and
First Problem:
Second Problem
Thanks
