integra clock spring question!
I have a GSR and i need a new clock spring.
i was wondering if i have to get a GSR one too or can i get an ls one or someother type of clock spring?
and from what year integra?
Looks like 94-95 GS-R and LS auto and 5 speeds are the same, the RS is diff.
You can check yourself... http://www.acuraautomotiveparts.org/...catdisplay.jsp enter car in dropdowns, scroll down to SRS and compare part numbers from year to year and model to model.
You can do the same at Honda parts... http://www.hondaautomotiveparts.com/...artsSearch.jsp and you would find a 94 Civic Si... http://www.hondaautomotiveparts.com/...S+UNIT+%282%29 has the same reel assembly as you 95 GS-R... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal and a 94 LS... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal 94
Ik this is an old thread but I’m having a hard time finding a clock spring. I have a 2000 gsr and was wondering if a 94 ls clock spring will still work. Ik it’s different part numbers but still has the same connectors and everything
94-95 is obd1
Don't forget to calibrate the clock spring before you install the steering wheel, or you will break it soon as you make your first U turn or sharp turn.
so any clock spring from 96-01 will work?
Found one rn that’s from a 98 4 door ls. Think only the rs and type r have different ones and every other integra from those years is the same one.
Just asking to make sure so I don’t go wasting the money.
Appreciate it and will do.
