Integra B20VTEC power problem
Old Dec 16, 2010 | 06:20 AM
jdmhonda31558's Avatar
Icon2 Integra B20VTEC power problem
ok ive been researching trying to find out what is wrong with my teg b20vtec. i have lost power and acceleration is weak. the car now sounds like its a freakin subaru and i hate it. i have changed out the plugs, distributor rotor, distributor ignition coil and the fuel filter and it still does it. does anybody know what i am talking about? help is really needed.
Old Dec 16, 2010 | 07:38 AM
highwhey's Avatar
Default Re: Integra B20VTEC power problem
check your timing?
Old Dec 16, 2010 | 07:42 AM
Icon2 Re: Integra B20VTEC power problem
what would cause the timing to change? what started this was me driving it and then someone tried racing me so i down shifted and hit the gas. after slowing down it started making the noise and loss of acceleration and power. would that still cause the timing to be off?
Old Dec 16, 2010 | 07:45 AM
highwhey's Avatar
maybe a bent valve...i know downshifting is fun and all but sometimes it isn't worth it.
Old Dec 16, 2010 | 03:38 PM
jdm_bones's Avatar
I am willing to bet that there are missing teeth in your timing belt...or more than one bent valves.
Old Dec 16, 2010 | 04:51 PM
1998GsRIntegra's Avatar
Either bent valve, a piece broke off an exhaust valve, timing belt jumped a tooth or a couple teeth, or you are missing teeth on the timing belt.
Old Dec 17, 2010 | 09:17 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
I'm gonna go with bent valve!
Old Dec 18, 2010 | 10:32 AM
JDMInteg96's Avatar
compression and leak down test...
Old Dec 18, 2010 | 11:05 AM
el crapitan's Avatar
compression test first. if you find a low cylinder, leakdown test.
if all cylinders are low, check timing
Old Dec 18, 2010 | 11:29 AM
JDMInteg96's Avatar
timing should be checked before both of those tests lol...
Old Dec 18, 2010 | 11:30 AM
dc2 teggy1120's Avatar
ide say bent valve aswell, ya and i agree with highwey downshifting is fun but not the best thing to do for ur car
Old Dec 18, 2010 | 12:09 PM
not necessarily, as a compression test will tell you 2 things at once: possible bent valve(s), or possible skipped timing
Old Dec 18, 2010 | 12:10 PM
speedooo's Avatar
whats the compression? b20's tend to crack sleeves when abused.
Old Dec 18, 2010 | 12:47 PM
fv8s's Avatar
Lets stereotype^^ I love when members assume that B20's sleeves aren't as strong as other VTEC/Non- VTEC blocks, yet people make amazing power on stock sleeves. What ecu are you running on this setup? Do you have an actual tune?
Old Dec 18, 2010 | 01:09 PM
speedooo's Avatar
Whatever you say chief.
Old Dec 18, 2010 | 01:58 PM
which block? b? or z?
what i mean is, were they the p3f pistons? or phk? is there a knock sensor on the back of the block?
regardless, compression test will guide you on your next step towards diagnosing the issue
Old Dec 18, 2010 | 04:25 PM
mouab18c1's Avatar
This! Check for proof on the All Motor Forum.
Old Dec 18, 2010 | 05:11 PM
b18T01's Avatar
what is your setup piston etc..,
any check light ?
check your tps sensor , fuel pump and injectors
Old Dec 18, 2010 | 05:47 PM
bks84's Avatar
Loved
Are you one of those people who had a bad experience with an B20V setup? Oh let me guess, you have NO experience but a friend of a friend of a neighbors cousins built a B20V, beat the **** out of it and it blew up. Thus, leaving a bad taste in your mouth, through no real experience... am I close? Regardless, you have no idea what you're talking about. I built a B20V in which I had a great experience, made good power and didnt crack a sleeve.
As for the question at hand: check timing first and foremost. Also, spill the beans on your setup. We need to know as much as possible to really help you out.
Old Dec 18, 2010 | 05:56 PM
fv8s's Avatar
At least I am not the only one in this thread that knows what they are talking about . And to the OP; check your mechanical timing as Cpt stated, you may find a couple of surprises.
zx92027xz
Aug 11, 2012 06:47 AM
johnk92
May 13, 2012 08:53 AM
pimpwagon
Nov 12, 2010 08:41 AM
john_lauj
Oct 28, 2008 09:33 AM
DrewDown
Nov 18, 2004 07:05 PM
