Integra Axle Weight difference?
Old Jan 9, 2009 | 12:20 AM
egkwhy08's Avatar
Default Integra Axle Weight difference?
So im looking for a new Axle for my 96 integra and I look through Autozone, kragen and Napa.
I notice a huge difference in the weight of different brand axles.
http://shop.oreillyauto.com/productd...pe=945&PTSet=A
From Kragen - Cardone CV Drive Axle listed as 26.00 lbs.
From kragen - GSP DRIVE SHAFT listed as 17.00 lbs.
From Kragen - Power Line DRIVE SHAFT listed as 15.00 lbs.
From Autozone - Duralast drive shaft listed as 15.35 lbs.
From Autozone - Duralast drive shaft listed as 16.25 lbs.
Why the hella is the Cardone weight so much more?
Is it a mistake?
Besides that some of them vary by 1lb is it because of the ABS ring?
Please provide some input.
Old Jan 9, 2009 | 12:27 AM
vietnamezerice's Avatar
Default Re: Integra Axle Weight difference?
i don't think the ABS ring will weigh 1 lbs....
Old Jan 9, 2009 | 06:21 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
It's not 26 lbs. That's just an error. 15-17 lbs. sounds about right.
Old Jan 9, 2009 | 10:41 AM
StokelesS_g2's Avatar
I know the 90-93 axles are thicker than the 94+.
And don't buy AutoZone axles.
Old Jan 9, 2009 | 03:10 PM
DOHCter ROOT's Avatar
that 26 lb piece might be the mid shaft and axel as one set?
dafreeeze
May 14, 2013 06:58 PM
supaf1y
May 9, 2010 11:34 AM
Burlyirishdude
Aug 7, 2005 02:59 PM
Bob_Digi
Feb 23, 2004 03:17 PM
