integ. ls is it or is it not ???
Old Jan 29, 2003 | 04:39 PM
cp_harrington's Avatar
Default integ. ls is it or is it not ???
My boy went for a ride in my hx civic and decided that he wanted an import so we went on the search finaly he found the one its a 96 integra LS b18b1 is the engine code but we cant tell if its v tec or not do all the ls's come with vtec or not and how will I be able to tell if his is vtec or not? I know this sounds stupid but Its an honest question. the vtec in my civic has 2 stages so its deffinatly noticable but his I just cant tell I cant hear it and sometimes the car gives a little kick like its vtec but not all the time is there anything I can do to check if its vtec? thanks
Old Jan 29, 2003 | 04:43 PM
leechungsr's Avatar
Default Re: integ. ls is it or is it not ??? (cp_harrington)
B18B1 does not have vtec. B18C, C1, C5 have vtec.
HONDA ENGINE CODES & HORSE POWER GUIDE
Engine Displacement Description Car Hp
EW4 1.4L & 1.5L SOHC PGM-Fi 84-87 Civic 60-92hp
D15B(?) 1.5L SOHC Non-VTEC 88-95 Civic 62-102hp
D16A1 1.6L L DOHC 86-89 Integra 86/87 113hp 88/89 118hp
D16A6 1.6L SOHC 88-91 Civic Si/ CRX Si 108hp
ZC JDM equivalent of D16A1 130hp
D16Z6 1.6L SOHC VTEC 92-95 Civic EX/Si 125hp
D16Y5 1.6L SOHC VTEC-E 96-00 Civic HX 115hp
D16Y7 1.6L SOHC non-VTEC 96+ Civic CX/DX/LX 106hp
D16Y8 1.6L SOHC VTEC 96+ Civic EX 127hp
B16A 1.6L JDM DOHC VTEC 89-91 Civic Si-R I/CRX Si-R, Integra RSi/XSi 160hp
B16A2/3 1.6L USDM DOHC VTEC 93-97 DelSol VTEC/99-00 Civic Si 160hp
B16A 1.6L JDM DOHC VTEC 92-95 Civic Si-R II/ 92-97 CRX DelSol SiR 170hp
B16B 1.6L JDM DOHC VTEC 98+ Civic Type R 185hp
D17A2 1.7L SOHC VTEC-E 01 Civic EX 127hp
D17A1 1.7L SOHC non-VTEC '01+ Civic DX/LX 115hp
B17A1 1.7L USDM DOHC VTEC 92-93 Integra GS-R 160hp
B18A1 1.8L USDM DOHC non-VTEC 90-93 Integra RS/LS/GS 90-91=130hp / 92-93=140hp
B18B1 1.8L USDM DOHC non-VTEC 94-01 Integra RS/LS/GS 140hp
B18C 1.8L JDM DOHC VTEC 94+ Integra SiR-G 180hp
B18C1 1.8L USDM DOHC VTEC 94+ Integra GS-R 170hp
B18C5 1.8L USDM DOHC VTEC 97+ Integra Type R 195hp
B18C6/7 1.8L JDM DOHC VTEC 96+ Integra Type R 200hp
B20A5 2.0L DOHC non-VTEC 87-91 Prelude 2.0Si 135hp
B20B 2.0L DOHC non-VTEC 96-98 CR-V 126hp
B20Z 2.0L DOHC non-VTEC 99-01 CR-V 143hp
B21A1 2.1L DOHC non-VTEC 90-91 Prelude Si 145hp
K20A3 2.0L DOHC i-VTEC 02+ RSX / 02+ Civic Si 160hp
K20A2 2.0L DOHC i-VTEC 02+ RSX Type S / 02+ Civic TypeR 200hp
K20A 2.0L JDM DOHC i-VTEC 02+ Integra Type R 220hp
F20A1 2.0L JDM DOHC non-VTEC 90-93 Accord Si 155hp
F20B 2.0L JDM DOHC VTEC 90-93 Accord Si-R 190hp
F20C1 2.0L DOHC VTEC 00+ S2000 250ps/240hp
F22A1 2.2L USDM non-VTEC 92-96 Prelude S 90-93 Accord LX/EX 130hp-135hp
F22B 2.2L USDM SOHC VTEC 94-97 Accord EX/97 2.2CL 145hp
F23A5 2.3L USDM SOHC 98+ Accord DX 135hp
F23A1 2.3L USDM SOHC VTEC 98+ Accord EX & LX/98-99 2.3CL 150hp
F23A4 2.3L USDM SOHC ULEV VTEC 98+ Accord EX & LX 148hp
H22A1 2.2L USDM DOHC VTEC 92-96 Prelude VTEC 190hp
H22A4 2.2L DOHC VTEC 97-01 Prelude VTEC/SH 97-98: 195hp 99-01: 200hp
H22A 2.2L JDM DOHC VTEC 92+ Prelude Type-S, 97+ Prelude SiR S Spec 220hp
H23A1 2.3L USDM DOHC non-VTEC Prelude Si 160hp
G25A1 2.5L USDM SOHC non-VTEC 96-98 2.5TL 176hp
J25A 2.5L JDM SOHC VTEC V6 JDM Honda Aspire/Sabre 200hp
C27A 2.7L USDM SOHC non-VTEC V6 86-89 Legend 150-160hp
C27C 2.7L USDM SOHC non-VTEC V6 95-97 Accord V6 170hp
C30A 3.0L DOHC VTEC V6 91-96 NSX/NSX-T 270hp
J30A1 3.0L USDM SOHC VTEC V6 98-02 Accord V6/97-99 3.2CL 200hp
C32A6 3.2L USDM SOHC non-VTEC V6 91-95 Legend Sdn, 91-92 Legend Cpe 96-98 3.2TL 200hp
C32A5 3.2L USDM SOHC non-VTEC V6 94-95 Legend GS Sdn, 93-95 Legend Cpe 230hp
C32A 3.2L DOHC VTEC- V6 97+ NSX/NSX-T 290hp
J32A2 3.2L USDM SOHC VTEC V6 00+ 3.2CL Type-S, 01 3.2TL Type-S 260hp
C35A2 3.5L USDM SOHC non-VTEC V6 3.5RL 215-225hp
J35A1 3.5L USDM SOHC VTEC V6 98+ Odyessy 210hp
J35A3 3.5L USDM SOHC VTEC V6 Acura MDX 240hp
Old Jan 29, 2003 | 04:44 PM
Phoenix_ITR's Avatar
no LSs came from the factory with VTEC. B18B is, in fact, the factory LS non-vtec engine code. GSR is B18C1 and ITR is B18C5.
-tony
Old Jan 29, 2003 | 04:49 PM
Default Re: integ. ls is it or is it not ??? (delinquent)
ok that answers that now hows bout this if I were to take a vtec'd head & computer and dropped it on the car will it's vtec work or are the compression ratios be different and screw things up internaly? the reason I ask is I have a type r head & comp w\ wiring harness. will the internals need upgraded or can i just swapp? and do i even have to add the head can I just put the comp in? thanx for all the helpfull replies!
[Modified by cp_harrington, 1:50 AM 1/30/2003]
Old Jan 29, 2003 | 04:51 PM
leechungsr's Avatar
a good LS/VTEC setup is much more than just a head and ECU. You need to raise the compression, get a vtec oil pump, and much more. Just do a search on the forum.
Old Jan 29, 2003 | 04:57 PM
Default Re: integ. ls is it or is it not ??? (Lee Chun)
ohhh taaa
thanx tons
Ill holla back here if i have any more q's.
thanx!
Old Jan 29, 2003 | 05:02 PM
eastsidemags's Avatar
mad ve-tchk y0
Old Jan 29, 2003 | 05:37 PM
RacerXintegra2k's Avatar
Default Re: integ. ls is it or is it not ??? (eastsidemags)
fo shizzle my nizzle ... i'm still a n00b here but i say search ls/vtec has been all over this place
stonedheckler
Sep 27, 2006 12:08 PM
crzyfool24
Nov 17, 2003 02:32 PM
YodaIsGod
Aug 20, 2002 01:09 AM
YodaIsGod
Aug 15, 2002 11:54 AM
